Guys out of interest im trying to remove the oil filter housing on my 03 td 3lt so i can do the oil change , i want to see if i can get that loose first before i dump the oil because i want to change the filter as well .
. according to the manual simply insert the 1/2 inch ratchet which i think is a pain , looks like previous attempts have fouled the square hole{ what a silly idea} , anyway i cant get the damn thing off , i am turning it anti-clockwise, im sure this is correct , for now disappointed ,
any tips ??????????????
I thought it was a 3/8 hole myself but doesn't matter if the hole is already damaged. Try putting a strap type filter tool around the outside of the housing.
It's a standard RH thread so you're trying to turn it the right way.
Thanks for the quick reply Tony , i might run into the workshop at work { Council } see if they can loosen it, then i will take it from there , bloody tight though.......
All good , workshop loosened it for me , they used a larger ratchet with an extension on it for more leverage , took it home , dumped the oil , changed the filter too good even sounds better , one job down , now for the next.............................................. ..............
