Yeah, I pulled the bracket out that held the jack in place and replaced it with that, I figured the standard jack wasn't going to lift the car so it had to go. The amp install kit works well, it is the right length, it's fused at the battery, it's thick enough too and easy to fit.
I used 9mm Square with no voltage drop seperate runs to both pos and neg on the batt. Anderson Plug is for the fridge, Got rid of the ciggy plug on fridge lead.
