G'day guys and girls.
So trying to find some room under my bonnet to fit my water separator filter aka fuel manager filter. Now there is sweet stuff all room anywhere!
Can I take all these vacuum hoses out? And just tape up the plugs and what have you. I remember reading some where that they are not needed? What are they for? It's a 4.2TDi
Or if anyone has a great spot to fit the fuel watch that also would be great!
Cheers Lewy
GU ST-L 4.2 turbo diesel Because reliability counts!!!!!
Front Elocker and a Heep more cool stuff :-)
Take it all out and put in a box in the shed never to be seen again. They are there for the very basic egr setup. You could go a step further and remove the egr all together. This frees up a lot of room for changing filters as it does away with the little cooler right above your oil filters. You only need to blank a small port on the vac pump which you can do very easily.
Well I already have the EGR plate in so sweet Ill just toss them away!! (blank a small port on the vac pump which you can do very easily)Where do i see this?
Thanks again Guys Its just so good having all the help from this forum!!
