8th April 2015, 10:51 PM
#261
550 is high mate. As boots has asked, what's your boost reading. I got 387c on the Hume and up the big hill just out of Seymour sitting on 110 clicks towing the camper. You should be getting lower than that imo.
8th April 2015 10:51 PM
8th April 2015, 11:21 PM
#262
Daily Lurker
boots
Hi Nic what is your boost reading when your getting to those temps and what size exhaust do you have ?
im running the stock exhaust and my max boost is set to 14 PSI. the new mechanic changed the dawes needle valve over when he did the rebuild as he believed the current one to be faulty. one thing you have all got me thinking about, maybe my reading is coming through in farenheit? as the mcnally gauges do both and maybe one of the mechanics changed it over without me knowing???
8th April 2015, 11:36 PM
#263
Dribble Master
rusty_nail
But then that would be approx 288 celcius, which would be pretty low if its working hard.... wouldn't it but i have no idea do ignore me, I'm just thinking out loud
8th April 2015, 11:51 PM
#264
Daily Lurker
im going out to the car to check now
8th April 2015, 11:55 PM
#265
@Rusty_nail That's pretty much what I'm wanting to do to my 2012 GU VIII. Great outfit.
9th April 2015, 08:13 AM
#266
Daily Lurker
Larx
thanks larx, yeah i like it mate. its a long way from the old GQ's i used to have thats for sure. a very comfortable and capable rig. have you got a build thread? i would like to check it out
9th April 2015, 09:13 AM
#267
Dribble Master
rusty_nail
Well.............
9th April 2015, 09:32 AM
#268
Daily Lurker
Clunk
Well.............
i cant work out how to change between f and c, but on option 3 the gauge reads C and then changed back to read mode. im fairly certain its reading at celcius also, as when i got in the car it showed 10.8 on the dial and the house thermometer was showing 11 degrees C.
ill have to take it to the mechanic this arvo and show him
9th April 2015, 05:41 PM
#269
How's the serenity
Mate drive by your gauge then and back off when temps climb. You could tweek with boost a little and get it higher but you may go to limp mode as things are. Unfortunately you need to spend more of your hard earned on a larger exhaust to get temps down to a more satisfactory range IMO.
9th April 2015, 06:47 PM
#270
Daily Lurker
boots
wait so higher boost would mean cooler EGTs? is that what your saying? and yeah i know i need the better exhaust, its just choking the motor atm with the stockie
