9th April 2015, 07:51 PM
#271
The 747
rusty_nail
wait so higher boost would mean cooler EGTs? is that what your saying? and yeah i know i need the better exhaust, its just choking the motor atm with the stockie
Yes higher boost equals lower EGTs, more fuel equals higher EGTs.
The Following 2 Users Say Thank You to Winnie For This Useful Post:
boots (9th April 2015), rusty_nail (9th April 2015)
9th April 2015 07:51 PM
9th April 2015, 08:09 PM
#272
Raise your boost levels until you hit limp mode, then back it off a tad to just under limp mode. You should get atleast 16psi, if not around 18...
9th April 2015, 08:45 PM
#273
Daily Lurker
So if I go fucking around with the dawes and needle valve am I going to run the risk of blowing up my motor? Or is this something I can do by myself? I'm so paranoid to change anything as I don't want to go blowing up the bloody thing again
10th April 2015, 03:14 AM
#274
rusty_nail
thanks larx, yeah i like it mate. its a long way from the old GQ's i used to have thats for sure. a very comfortable and capable rig. have you got a build thread? i would like to check it out
Once i get my tax back i'll start doing my mods. Im'm going to start a build thread with heaps of pics & when i start doing my own servicing i'll make a few videos.
10th April 2015, 09:05 AM
#275
rusty_nail
The only way you could blow your motor up with the Dawes and needle valves is if you were to set the boost way too low and just drive it. Your EGT's will go through the roof, cylinder temps will be massive and you will melt pistons again. But if you were to drive with such low boost the car would under perform so badly....
rusty_nail (10th April 2015)
4th May 2015, 02:14 PM
#276
Daily Lurker
ok so i discovered a problem over the weekend. i was out 4wding and at the beginning i went to take out my tow hitch. turns out the bloody thing is rusted in their solid!!! does anyone have any clever ideas about how to get it free so it can be replaced as at the moment i can only see it being a hazard...
4th May 2015, 02:18 PM
#277
The 747
Yeah cool, where did you go? First time 4WDing since the rebuild?
I would just keep soaking it in WD-40 and try use a hammer to knock it out, maybe use a bit of heat
4th May 2015, 02:22 PM
#278
Daily Lurker
ok heat and WD40. like oxy heat or heat gun heat? lol. went to yalwal and yes first time off the tar since the rebuild. the car went great, except i damaged a rim on the way out. went the whole way out without doing any damage and then damaged the rim. gotta have more of a look as it was dark when i got home and see if i did any other damage
ill throw some pics up in a min
4th May 2015, 02:38 PM
#279
rusty_nail
WD40 and a hammer flood the coupling with it and tap it to try and brake the seal it,l take a bit to loosen
4th May 2015, 02:40 PM
#280
@ Rusty hopefully if only a steel rim you can belt it back into position.
As for the tow hitch beat it on all sides and soak in WD40, you
may be even able to put a piece of pipe or similar in from the back and belt it out that way.
As for your dawes etc I take it you have gauges fitted already, if so hard to go wrong,
1/2 to 1/4 turn at a time
