Results 1 to 10 of 10
Thread: Removal of Window Winder Handle GQ 1992
    Feb 2011
    Western Australia
    Hi, I have a H&&?? workshop manual and looked up how to remove the window winder handle.
    All it says is remove the window winder crank using a hooked tool to remove the retaining clip.
    I can't see how or where to remove the retaining clip on the actual handle. A photo would have been good. They put one in on unscrewing the locking button but not showing where / how to remove the retaining clip. Strange.
    If someone could help it would be most appreciated.
    Paul
    Feb 2011
    Western Australia
    Sorry I forgot to mention I did do a search on the site before posting and only found information regarding electric to manual conversion.
    Paul
    Hi cobber,
    OK... if you push the trim in and look closer you will see a "C" shaped circlip of small diameter wire. It sits in two slots of the plastic boss of the winder handle and the clip is not very big... it is made out of maybe 1mm dia wire if that
    If you slowly rotate the handle while looking down between the handle and trim you should spot it easily
    In the centre of the "C" is a slightly bent section that sits proud of the boss and you can get a Crotchet Hook or similar into and pull the Circlip out. Not being into crotchet I used a bit of stainless wire about 3mm in dia to make the tool but ingenuity should find something around teh house for you to use.
    Replacement clips are about $2 at Nissan because Murphy says at some stage one will "fly" away never to be seen again but if you are careful you can reuse them any number of times
    bugsy (6th February 2011)
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    That is why they are called Jesus Clips
    Banned
    Quote Originally Posted by Bob View Post
    LOLOLOL....... Patrols have a lot of them........
    ROFL... Gold
    If that was the case in my shed they'd be called "Arrrgh FFS Clips"
    Feb 2011
    Western Australia
    Hi cobber,
    Excellent thanks mate,
    That was explained simple and clearly enough for even me to understand.
    Much appreciated.
    Paul
  10. #8
    Oct 2010
    Pakenham
    47 Post(s)
    Its great to see you acknowledging ET for solving your problem. Well done
  11. #9
    Feb 2011
    Western Australia
    Replacement of window winder handle.
    And for those who may read this thread at a later date. Replacing the handle is easy. Replace the clip on the handle, and push the handle straight onto the splined shaft. As the end of the shaft is tapered it spreads the spring and then clips back into place on the slot. Don't forget to fit the grey stepped surround to the window winder crank handle before replacing it.
    Paul
  12. #10
    Benarkin QLD
    Also put your hand near the end of the handle,where the clip could "Fly"off
    Some are not just a simple push on ,with extra force the clip parts company and off it goes,thru the air
