28th March 2014, 09:41 AM
Leave the original block there or the floor will start to crack
28th March 2014 09:41 AM
28th March 2014, 10:09 AM
They may be internal thread and bolt from underside..
But you should be right to lift a little and knock em out.
They'll either move or not..
28th March 2014, 10:16 AM
Appologise for thread hijack, but with those supports under the cargo area, should they be touching the body as mine has about a half inch gap between the mount and body. Don't have a body lift.
28th March 2014, 11:02 AM
Parksy
I'd say yes.
You've put new mounts in thou haven't you, so the 2 in question have probably compressed with the old mounts.
Have not seen em for sale though..
Might make some uhmw ones as I'm guessing mine will be the same..
28th March 2014, 11:56 AM
Moderator
I bet those blocks have been glued in with Sikaflex or something. If there is no fixing from above than thats the only way. They are only there as bearing points should you put a load in the back and the rest of the time basically just Rub under the floor. I know plenty of folks that had nothing there, i have a length of timber as i said as its not structural but needs to bear load only.
If you cant see a fixing then expect them to be glued i reckon.
Check out my Toy -->
Rogue Dung Beetle
28th March 2014, 01:35 PM
MudRunnerTD
My draws are in full time now so me thinks I won't bother with then..
31st March 2014, 07:57 PM
#17
Westy's Accessories
Blocks are accessed from under the car so you don't need to remove draws, just noticed one of mine has fallen out.
31st March 2014, 08:17 PM
#18
liftlid
Yea I ment my draws spread the load so I'm not gunna worry about the blocks..
