26th March 2014, 10:19 PM
Advanced
indicator on speed
i replaced my stock rear tail lights with led replacments,
right side all good, left side not so!
its flashing really quick? ive checked the earth, fuses, front and side indicator are workin but flashin same speed, i disconnected the tail light n the front n side still flash fast??
any ideas fellas?
cheers
26th March 2014 10:19 PM
26th March 2014, 10:23 PM
Legendary
Menis,
Are all the globes working on each side, as the globes will flash fast when you have any of the globes not working...
Mic
26th March 2014, 10:28 PM
Legendary
The other trick you can do is to add a resistor across the led globe, so the flasher sees the same resistance as it would with a traditional globe. Add a 7 Ohm resistor across the globe wires, and that will fix it
Mic
26th March 2014, 10:40 PM
You have reduced the load of the indicator circuit by fitting the LED tail lights. The flasher relay need a certain amount of load to flash the light at a certain rate. When the load is reduced the lights flash quicker.
You have two options, replace the flasher relay with an LED compatible one or fit load resistors to the indicators.
26th March 2014, 11:01 PM
Advanced
yeah all the globes are working happygtu,
thanks for the posts fellas, ill cruise into supercrap tomorrow n get a couple load resistors.
cheers
