Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 65
Thread: LRA GQ LWB auxiliary fuel tank install manual
  1. #31
    43 Post(s)
    Is the brown Davis tank a petty tank bloke?
    May pay before you fit it mod it to the bigger deisel hose size..
    Thomastown, Melbourne
    6 Post(s)
    The brown davies was on my car from when it was petrol gas set up and the filler hose was a mother to get on if it was ever removed..
    the issues I have are with the down sizing to the smaller hose size and having mixed match hoses and reducers so looks messy and there is room for errors..
    This is why I am going with complete matching set up as the tank was free I am not out of pocket much and it is all supposed to fit straight up.
    Going back to my original question about drilling holes for the mounting brackets... does anyone remember??
  4. #33
    581 Post(s)
    Quote Originally Posted by Bloodyaussie View Post
    The brown davies was on my car from when it was petrol gas set up and the filler hose was a mother to get on if it was ever removed.. the issues I have are with the down sizing to the smaller hose size and having mixed match hoses and reducers so looks messy and there is room for errors.. This is why I am going with complete matching set up as the tank was free I am not out of pocket much and it is all supposed to fit straight up. Going back to my original question about drilling holes for the mounting brackets... does anyone remember??
    I think we just sat the tank in the spot whilst someone marked the holes on the cross member?
    Bloody can't remember either!
  5. The Following User Says Thank You to AB For This Useful Post:
    Bloodyaussie (18th January 2016)
  6. #34
    43 Post(s)
    Looking at a few install threads ab's correct.
    Hold mark and drill..
  7. The Following User Says Thank You to BigRAWesty For This Useful Post:
  8. #35
    6 Post(s)
    Those lra fitting instructions have all the bolts listed so will get what i need and start after this frickin heat f$#ks off.
  9. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    BigRAWesty (18th January 2016)
  10. #36
    43 Post(s)
    Tell me about it lol. Need to polish a couple of cars but that ain't going to happen
    Yeah that's what we did!
    We did use reducers for the filler necks and I think that's why we are having a bit of trouble with high flow diesel pumps.
  12. The Following User Says Thank You to Winnie For This Useful Post:
  13. #38
    581 Post(s)
    Mainly aimed at Winnie but the hose we ran for the aux tank filler was a bit dodgy mate.
    Patrolapart cringed at what we did and they showed me a kit they get off LRA which comes with the properly bent pipe from your neck and sneaks between the chassis rail and body over the main tank directly to the aux tank.
    Even though we did the Simpson and countless other trips it is a bit dodge mate and rubbing. I actually completely forgot about that hose we ran and it's still rubbing and will fail in years to come.
    I decided to buy it mate so let us know if your keen. It was a hundred and something, can't remember exact price but it comes with all the fixings and hoses, bends etc to perfectly suit.
  14. #39
    Hey mate, yeah I did notice it a while ago when I was under the car. I will get that kit soon
  15. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    AB (29th April 2016), BigRAWesty (29th April 2016)
  16. #40
    6 Post(s)
    I fitted that kit some months back and is a million times better..... can be bloody tricky getting that metal pipe to squeeze its way into position and it helps to at least take out the bolts towards the front of the main tank so it drops.a bit to give you a bit of room to get it in.
    I rang lra and they gave me a clue as to how it went in but said it was a very long time ago since they fitted one last.. they also said it comes on from the bottom front.
    Once in it is so much better than a dodge hose.
