Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 65
Thread: LRA GQ LWB auxiliary fuel tank install manual
    581 Post(s)
    Ok small question..
    I have 2 ports at the rear of the tank.
    1/2" and 3/8 I think.
    I have all the correct filler and breather ports at the top of the tank..
    So???
    Do you mean the ports are at the top of the rear part of the tank or the bottom of the tank?
    Wang some photos up???
    43 Post(s)
    So you can see supply and return on the sender unit,
    And filler, quick fill breather and expansion breather.
    Then 2 more left of pic, which are at the rear of the tank..
    And yes, I'm missing a mount..
    581 Post(s)
    No idea mate, I'm on the phone but there is another diagram on here ill try and find for you which may help solve this.
    Looks like your missing a mount too?
  5. #14
    581 Post(s)
  6. #15
    43 Post(s)
    Yep um guessing that mount is that pita one to get off. If only I knew a decent welder... ;-)
    Seems weird to have a pickup on the sender and tank??
    581 Post(s)
    Also Westy being yours is probably the same as mine and out of a carby to be used as an aux tank on a dual neck filler you will need a reducer for the aux filler hose.
    The aux tank will be 48mm, I can't remember what the neck will be but it will be smaller in diameter so you'll need a reducer.
  8. #17
    43 Post(s)
    Na not running a dual filler neck, I'll be running an overflow setup.
    43 Post(s)
    Found it!!!! 4th page of a 'LRA sub tank maunal'....
  10. #19
    Advanced werasmus's Avatar
    Aug 2013
    Sorry for resurrecting old post, but what do you mean by overflow setup, I'm at that point now. Thanks
  11. #20
    465 Post(s)
    Quote Originally Posted by werasmus View Post
    Im assuming if he's only using one filler bascially the aux tank gets filled once the main tank is full. I assume the main is connected direct to the aux and it basically overflows into the aux tank.
