25th March 2014, 04:43 AM
#21
happygtu
Alexander,
In the north of Australia, the kids ask questions like ..... Dad, what do these buttons do and why does that dial go to red when you turn it clockwise, ..... when they look at the heater controls .....
In Tasmania, they dont even have AC as an option when they buy a new car ....
Mic
Great! In this case if it is coolant (I hope it is not) just loop the system before the firewall under the bonnet and this will solve the problem forever!
I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
25th March 2014 04:43 AM
25th March 2014, 09:48 AM
#22
The Following 2 Users Say Thank You to happygu For This Useful Post:
Pokey (25th March 2014), Wine_maker (25th March 2014)
29th March 2014, 08:12 PM
#23
It only smells like coolant. And if the water level in the radiator isnt dropping fast, then its not coolant frm the heater core.
These are only speculations, anyway.d
29th March 2014, 09:08 PM
#24
Travelling Podologist
If it isn't coolant you might find an answer in this thread.
http://www.nissanpatrol.com.au/forum...!!!!!!!!!!!!!-
18th May 2014, 08:24 AM
#25
Water on passenger floor for me was leaky windsheild around the rubber and heater core tap. If it were heater related I reckon tap or hoses rather than core itself. Youve got to remove pretty much the whole dash to get into it safetly, at least with my mq its a simple job took 15 minutes. Assembling it all back can be a bit daunting for the first time but isnt hard either. Hope you resolve ya issue
19th May 2014, 12:56 PM
#26
It was a rubber bung on on the bottom of the cab that popped out
The Following User Says Thank You to statok For This Useful Post:
10th July 2014, 08:16 AM
#27
I had the same problem few months back. It was the windscreen rubber seal leaking for me. I went to supercheap auto and got some windscreen glass black sealant and sealed it myself. All good now.
2nd January 2015, 08:49 AM
#28
Hi Guyz,
A week ago my patrol was on oil changes etc ... And as I was having the same issue with water on the passagnger floor I asked the maintenance Guyz to call me wen they will take the cabin filter out --- then we found the AC drain pipe was kind of bended inside and so the outflow of the water was not that smooth and it was leaking there - most likely going thr some ups and downs not likely when running on the flat road.
I was today goin thr some kind of sand mining area and so far not seen anything on the floor. The pipe looked to be not that strongly connected so it might be the problem in other cars as well.
Rgrds, Krzysztof
The Following User Says Thank You to Krzysiek79krzysiek For This Useful Post:
Stropp (2nd January 2015)
