Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: What size Solar Panel ???
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    My present configuration in our Caravan is as follows :-
    110 AH Deep Cycle Battery in Van
    Redarc BCDC1220-IGN DC to DC Battery Charger in Van
    Anderson Plug connection from Battery in the Patrol to the Van to Charge Caravan Battery whilst travelling.
    Running from Battery in Van:-
    LED Lighting
    12V Computer Fan which improves Air Flow over the Caravan Fridge Condensor.(only runs on Hot Days)
    Shower Pump (Maybe once a Day for 10 Minutes)
    We intend to Purchase a Camping Fridge/Freezer (Compressor type) 50 Litre
    My question is what size Solar Panel would be appropriate to charge the Caravan Battery whilst Camping.
    W.A. (wandering aust)
    Minimum 120 Watts (twin 60 is easiest to store) with a quality MPPT regulator.
    Mount the reg close to the battery not on the Solar panel like some do.
    The Redarc you have has an input specification that will handle Solar Panel output voltages but don't, IMHO a dedicated MPPT regulator is a better option
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    Bob (20th March 2014)
  5. #3
    Oct 2010
    Pakenham
    47 Post(s)
    What do you think ET ?? or anybody else
    http://www.ebay.com.au/itm/NEW-120W-...-/221371443982
  6. #4
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Jump on it bob thats a good price
  7. The Following User Says Thank You to Sir Roofy For This Useful Post:
  8. #5
    are you fitting it permanently on the roof ??
    In perfect conditions your putting back 6.7amps
    yeah not bad
  9. The Following User Says Thank You to threedogs For This Useful Post:
  10. #6
    Oct 2010
    Pakenham
    47 Post(s)
    No not fitted permanently.
    In view of ET's comments I should possibly purchase one with a MPPT Regulator. (He is the Guru)
    Have emailed REDARC for their opinion also.
  11. #7
    no big deal to chase to sun, by re positioning it.
    should be a spot on set up with out side led lights.
    Are the lights in the van LED? if not cheap enough to change
  12. #8
    Oct 2010
    Pakenham
    47 Post(s)
    All lighting is LED both inside and outside
  13. #9
    you'll love solar the more you get into it,
  14. #10
    Oct 2010
    Pakenham
    47 Post(s)
    A bit off subject but are in the process of getting quotes for Solar Panels in the House
  15. The Following User Says Thank You to Bob For This Useful Post:
    threedogs (20th March 2014)
