5th September 2014, 08:46 PM
Doka's TD42 Safari Shorty
Well its been a while since I have had a patrol. But I got the hankering for another one a few months ago..
Now there is just something about a GQ I like and Ive always wanted a shorty..so I managed to pick up a 1989 TD42 Auto SWB Safari (Jap Import). Had around 197000 km on the clock when I got her (Just clicked over 200000km now)
Its been a slow 'work in Progress' kind of build and have been focusing on making sure its good to go mechanically rather than major mods..
but here she is as I got her..
So when she first turned up the got all the normal stuff..new batteries, coolant flush, all fluids changes etc
It runs extremely well..in the last 10000k it has had (by the previous owner) :
New Injector Pump
Head Rebuild
New Air Con Compressor
New Radiator
New Torque Convertor
New Shock/Springs
as well as a lot of other bits and pieces...but I have added...
All the oils have been changed (somehow they squeezed 8 litres of oil into the front diff!)and the only thing left to replace is the brake fluid, but its still pretty good (had it tested). I will be getting new disks/pads and braided lines so it will get changed then. Going to rebuild the front swivel hubs and do wheel bearings while I am there.
Rear cargo area, quarters and doors have been dynamatted and Focal Bam has be put over that to sound proof it. Now just got to get some more and do the front floors.
Enlarged the hole through the firewall (the one where the clutch would go through if it was a manual). Well actually did not enlarge the firewall hole, just made a new cover plate so I can run the wires through properly. Had to make a 'horseshoe' plate as there was existing wiring and have used Dynamat to help seal it all up.
Diff breathers just about done..had to make a bracket for them..
New Wheels and tyres are on..running 17" Mickey Thompson Classic 3 Alloys with BFG KM2's (roughly 33's).
Upper Adjustable arms going in this weekend. Have a dual Cardan driveshaft for the rear so thinking of getting a second hand housing and re-locating the coil hats etc so I can run that..but its not a priority at the moment.
New Dobinson 2" Coils have gone in..they are their flexi coils..so time will tell how they go.
Also got some 4" Dobinson Remote Res Shocks in it, but they seem too still so they may get revalved/replaced
Extended Bumpstops front and rear are in..
Icom UHF is in..
Staying with the factory bar for now..so that's been tidied up. Also rebuilt/tested the Factory Winch and put that back in with Synthetic rope. Had to re-do the front fairlead but it came up pretty good in my opinion. Have kept the factory wiring for the winch, but have wired the original solenoid that provides power to the winch to a switch in the cab. Wired in a wireless remote but will also wire in a Winch IN/OUT in cab as well.
Been deciding on what switch gear to use and after too'ing and fro'ing have gone with Honeywell MilSpec toggle switches..nice switches and water/dustproof..just not cheap.
New Headlight reflectors and uprated globes in..Wiring lights wired up..but need to replace the lights as the headlamps outshine them..so for now got some cheap ebay 55w HID's..cant really argue with them when you pay 143.00 for 4 lights..so I got spares when they fail.
Had to get a new Spare Tyre Carrier bracket as the standard one wont fit a 33' it sits the spare lower than a normal Aus patrol one..But a foum member (Thanks DieselJoe) came through for me and sorted that out.
Gauges/sendors and adapters have arrived (VDO 24v) just waiting on the gauge pod and they can be fitted
Been thinking of turbo options..but have a few things I need to do before that. Have to get the Trans cooler and Thermo fitted, also going to put an additional thermo fan on the front of the Rad (in front of the AC Condensor) and have it switched in-cab so if I am crawling around I can switch it on to help keep things cool. Will have the thermo on the Trans cooler also switched in-cab.,
Started the wiring for the rear Aux power outlets..but I have to decide where I am going to put the 24-12v reducer and the additional battery in the back. Going to get a sheet of alloy made for the back as a base to hold the fridge etc so need to nut out exactly what I am doing there..I am not going with a draw system as I don't want the additional weight of one so trying to keep it simple and light. Once I sort that out I can work out where the Battery and ARB Twin-pump compressor will all sit and get that sorted etc.
other bits and pieces being sorted just as part of a tidy up..got enthusiastic and claybarred the truck..and gave it its first coat of wax..so it needs another quick wash and some more wax..few little bits of trim to tidy up..but its getting there.
New Head unit went in, so now need to upgrade the speakers..
The Following 4 Users Say Thank You to doka404 For This Useful Post:
AB (5th September 2014), Clunk (5th September 2014), growler2058 (7th September 2014), NissanGQ4.2 (5th September 2014)
5th September 2014 08:46 PM
5th September 2014, 08:47 PM
The Following 3 Users Say Thank You to doka404 For This Useful Post:
5th September 2014, 08:48 PM
The Following 5 Users Say Thank You to doka404 For This Useful Post:
Clunk (5th September 2014), growler2058 (7th September 2014), mudnut (26th October 2014), Stropp (8th September 2014), Woof (5th September 2014)
5th September 2014, 09:29 PM
Rotaredom
5th September 2014, 09:38 PM
BIG & BALD
Wow, that Trol looks pretty Schmick.
5th September 2014, 10:17 PM
Dribble Master
Mate, that has got to be the cleanest engine bay I have ever seen and the rest of the car isn't that shabby either......... looks great
5th September 2014, 10:27 PM
Thanks Mate..I was real lucky with it as I bought it sight unseen off gumtree and was quite happy when it arrived as good as I thought it would be.
Its been a bit of a labour of love over the last few months..had to be engineered to be registered as its an import. NSW don't recognise the QLD Rego/ADR Approval. But really its just been a case of slowly going over it and making sure its all ship shape.
Considering it was completely stock and unmolested (still has the original exhaust on it, paint is all original,still had the Nissan Winch cover and even has a full compliment of unbroken grill clips lol ) ..I reckon its worth the effort.
Its a long way from being finished..but its slowly taking shape..
The Following User Says Thank You to doka404 For This Useful Post:
7th September 2014, 07:12 AM
7th September 2014, 07:20 AM
7th September 2014, 07:42 AM
growler2058
Love the Mickey T rims mate
17's may not be everyone's choice, but she won't be a tourer..really just a toy for weekend runs and the like
So its a bit different and yes the tyres are a bit more exxy..but I like how it looks lol much better than the gold steelies it came with..
Its been a while since I have gone to this much trouble on a truck that was actually mine, so any suggestions or tips on things I could do or could have done matter..post away!
