19th March 2014, 02:20 PM
#11
type in code faults in advanced search right top
go to bottom of page and read ynots notes this might help you
plus there is more there
19th March 2014 02:20 PM
19th March 2014, 08:09 PM
#12
The Big Rig
how do i check the cat? just check the flow from the rear of the car? cheers
yes have it running and get someone to give it a rev to see if its exhausting properly, also when exhaust is totally cool tap the system with your hand to see if there are any unusual rattles, reason I mention this, a mate had complete loss of power on his nissan and rattling real bad,a diesel mechanic told him the timing chain was buggered and had slipped, I tell ya I laughed my guts out, anyway i'm a petrol mechanic and quickly found the issue, he was so wrapped, as the mechanic had quoted $8000 to fix the engine,my mate had it fixed at the exhaust joint for a mere $500 the next day, and just out of spite we pulled into the garage and the mechanic came out with a dumb look on his face, and I yelled at him $500 is a small price compared to your $8000 quote I said your not a mechanics arse LOL
17th April 2018, 10:05 PM
#13
Having similar issue again actually had the injector pump blow up spent $5,000 was fine for about 5months and now it’s starting again here’s what l have found on code 77 it is P0077 Intake Valve Control Solenoid Circuit High B1
On vehicles equipped with variable valve timing (VVT), the Engine Control Module / Powertrain Control Module (ECM/PCM) controls the camshaft position by regulating the engine oil through the control solenoid to change the position of the camshaft. The control solenoid is commanded using a Pulse Width Modulated signal (PWM) from the ECM/PCM. The ECM/PCM monitors this signal and if the voltage is above specification, it will set this trouble code and illuminate the Malfunction Indicator Lamp (MIL).
Bank 1 refers to the side of the engine with cylinder #1 - be sure to verify according to manufacturers specifications. The intake valve control solenoid is usually located on the intake manifold side of the cylinder head. This code is similar to codes P0075 and P0076. This code may also be accompanied by P0026.
Symptoms
Symptoms may include:
•Check engine light illuminated (Malfunction indicator lamp)
•Vehicle may suffer from poor acceleration and decreased fuel economy.
Potential causes of a P0077 diagnostic trouble code may include:
•Wire harness poor connections or disconnected
•Control solenoid open circuit
•Short to power
•Faulty ECM
17th April 2018, 10:28 PM
#14
Daily Lurker
The Big Rig
hey all, just after some advise, was driving my gu3 zd30 the other day and engine warning light came on, and lost power, im guessing limp mode. took it to a diesel specialist and had it scanned, it is coming up with code 77. he has told me that my pump is stuffed and i need to buy a new one. i have tried to do a little research on the code before forking out for a new pump but cant seem to find much on code 77, except some references to 0707. are they the same code? or does anyone now what code 77 is exactly? would like to make sure it is the fuel pump before getting it reconditioned. when i first got the code a mechanic mentioned that it may be a blocked fuel filter, so had that replaced and fault still appears. when i first start the car it doesn't show code and seems to have full power for about 5 seconds, then engine light appears and power loss. cheers, Geoff
hey mate have you tried flushing the fuel filter? there is a nipple on the bottom, engine light sometimes indicates a dirty filter
