Results 1 to 10 of 10
Thread: Gvm upgrade
    Sep 2011
    Mount Annan
    Gvm upgrade
    I’ve been reading and learning, but not posted anything for a while.
    I’ve 2005 4.2td wagon, 2” lift, genuine bull bar, rear Raslar steel bar with spare wheel carrier and twin jerry holders and drawers in the rear.
    Didn’t come as a surprise that GVM was almost reached.
    I’ve since bought a 19’ caravan that weighs around 2550 (TBW = 250 kgs)
    Now that’s outlined, I’ve recently had patrol GVM upgraded to 3550 kgs. Obviously with heavier coil springs.
    My question is:
    On original springs I had airbags that assisted when towing. Now that I have the higher rated springs -
    Do I need the airbags, or should I trust the upgraded springs to do their job
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I have the same upgraded 3550 kgs GVM with 300 kgs springs and heavily loaded rear drawers, etc. My van can get to 2.7t if I need to carry 200 kgs of water and I put 260 kgs on the towball.
    I opted to keep my Polyairs when I upgraded the suspension because they were nearly new and I put them at 10 psi when towing even if I probably don't need to.
    I also use a WDH (with anti sway cams) to move some of the weight to the front and that keeps it all pretty level. If I don't do the weight distribution, the front feels uncomfortably light.
    John
    194 Post(s)
    Have you installed the BOSS Tower strengtheners or weld in units in the rear towers? I would recommend this with the airbags, a lot cheaper than repairing a torn mount.
    Apr 2021
    Brazil
    How does it perform such weight transfer?
    Morayfield, QLD
    It works as designed with my setup. Not always recommended for some vehicles.
    John
    Morayfield, QLD
    That would have been an essential mod even without the GVM upgrade. I used the Boss units for mine because the weld in stuff requires engineering.
    John
  8. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    MudRunnerTD (31st August 2022), PeeBee (30th August 2022)
    Sep 2011
    Mount Annan
    Gvm upgrade
    Thanks jff45
    I had some further conversations yesterday with someone who I trust and has knowledge in this area and he convinced me that the airbags are not required. So I decided against them.
    As for steering I find very little change with van on, so no wdh used. The van and truck sit level and tows very well.
    I now have a brand new set in their box unopened that I’ll sell
  10. #8
    Sep 2011
    Mount Annan
    Yes towers strengthened during upgrade
  11. The Following 2 Users Say Thank You to shakey55 For This Useful Post:
    MudRunnerTD (31st August 2022), PeeBee (31st August 2022)
  12. #9
    Morayfield, QLD
    Quote Originally Posted by shakey55 View Post
    Thanks jff45
    Still might be worth getting it onto a weighbridge with all the weight on the rear to see how your rear axle loading is without the WDH.
    It's good to have knowledgeable friends but the weighbridge will be more accurate.
    John
  13. The Following User Says Thank You to jff45 For This Useful Post:
    DX grunt (3rd September 2022)
  14. #10
    WA Wheatbelt
    23 Post(s)
    So diplomatic. Well done, and thank you.
  15. The Following User Says Thank You to DX grunt For This Useful Post:
    jff45 (4th September 2022)
