11th March 2014, 08:34 PM
oil leaks
Hey guys/girls
Just going to crawl under the patrol to see what needs doing and was wandering what I should be looking for in the way of oil leaks. I have a 4.5Ltr petrol
11th March 2014 08:34 PM
11th March 2014, 08:38 PM
Not sure what you are asking to be honest??
Some of the main ones that are a worry are the rear main between the engine and gearbox... then there is sump gasket can leak and is more a pain in the ass than the end of the world..
It there are any leaks you should give the engine a good clean as it is hard to tell where they are coming from.
11th March 2014, 08:42 PM
aj_vmax
Hey guys/girls
Pretty much what you said. Oil leaks. If you see oil leaking, then worry. As BA said. Not really sure what your exactly asking...
11th March 2014, 08:59 PM
Sorry just thought there might have been some common spot to look out for.
11th March 2014, 09:07 PM
No need to appologise bud. Your question was very general that's all. Just look and see. If you see a leak then come back to us. If you don't, then sweet.
Cool just trying to do a little maintenance on the girl before things go wrong. I do have a rubbing noise coming from the front it only happens when u hard lock to the right. I did think it was the front left bearing but she it tight and no movement. Any ideas
Reason: messed up
11th March 2014, 09:21 PM
Which side is the rubbing noise coming from?
11th March 2014, 09:22 PM
Left. I have also checked right front hub and no movement either.
11th March 2014, 09:25 PM
Car lifted? Tyre size? Are the front mudflaps still on the car?
11th March 2014, 09:27 PM
No std. Std rims. I have looked and cannot find anything grinding marks
