10th March 2014, 05:43 PM
03 GU oil light
Hi all I have a 03 GU zd30 I have been led to believe there is a known problem with the oil light staying on
The fix to it is a new resistor
Has anyone done this ... Know where the resistor is located
I would like to do it my self just need to know where the resistor is located
10th March 2014 05:43 PM
10th March 2014, 05:54 PM
Mine had the dodgy oil pressure switch, but it happened about three weeks after buying it new.
Fix was to replace the sensor, and it was and has been fine ever since.
Mic
10th March 2014, 05:55 PM
Mine was an 03 model too, and it seemed to be a batch of sensors at the time, as mine wasnt the only one
10th March 2014, 06:02 PM
The resistor is in the driver side kick panel. Just near the accelerator pedal.
10th March 2014, 08:24 PM
Thanks guys
Turns out there is two sensors one under the turbo and one next to the starter
I had only changed the one I knew of under the turbo
I have now changed the other and problem seems to be fixed oil light is going out straight away
11th March 2014, 11:31 AM
I just fitted an oil pressure gauge bud, that way I know exactly what's going on (or not, as the case may be) with the oil pressure.
11th March 2014, 03:53 PM
Happens to the 04 models as well but doesn't do it as often lately
11th March 2014, 04:34 PM
threedogs
I just disconnected the resistor on my old GU4.
The light worked normally and no other problems.
Nissans recommended fix is to replace both senders and resistor.
The Following 2 Users Say Thank You to Yendor For This Useful Post:
Barrbeast (11th March 2014), threedogs (11th March 2014)
29th June 2014, 08:59 PM
I just found that there is two switches now, I had replaced the one under the turbo twice! Replaced the one near the starter! Has worked fine all day
