6th March 2014, 04:00 PM
TD42T 3" system upgrade options !!
The back ground is my new-ish 2002 GU wagon has a dump pipe back 3" system.
But a standard dump me thinks looking at it as still has OEM heat shield attached to it.
And a slight leak on muffler output so a new system altogether is on the cards.
Looking for info to chew over , which exhaust system and configuration to install.
And if ya can clue us up on what new system works with std turbo and a possible upgrade eg-say a GT2860 for instance.
Or others models turbos, what ever goes with this or that is what I want to know about please.
Now was considering a new 3" dump, but cast or steel? as both available.
and then there's ceramic coated steel or cast also. humm.
The twist is there also seems to be engine pipe available that does away with the dump altogether, what's the best set up for engine pipe area please??.
And also what about this,http://www.ebay.com.au/itm/171235414...84.m1423.l2649
See on ebay Xforce mild steel and stainless available.
Some feed back on xforce please. think they do away with dump and use the longer engine pipe instead.
think that covers it.
Whats the go people's.
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
6th March 2014 04:00 PM
6th March 2014, 04:15 PM
Check out Scott's rods mate in the vendors section.
Very well priced imo..
6th March 2014, 04:19 PM
Moderator
That link on eBay show the stainless system for $910.
Check out the vendors section here for a great deal
Scott's Rods - Performance-Exhausts
Check out my Toy -->
Rogue Dung Beetle
6th March 2014, 04:44 PM
MudRunnerTD
Yep good price for stainless,
but what about strength on hangers etc ?.
I'll ring Scott's thanks, after I hear from the online experts.
I'm asking these questions as I've been dealt a blow,
plain ripped off, inferior product and performance by an exhaust shop in the past.
and want my fellow patrolathons input first.
The Following User Says Thank You to Robo For This Useful Post:
BigRAWesty (6th March 2014)
6th March 2014, 05:02 PM
Robo
At that price it would be cheap stainless.
And really unless your gunna show it Off stainless ain't really needed for a diesel.
6th March 2014, 05:16 PM
Moderator
heard nothing but great feedback from Scotts Rods. Regardless of their support here the forum approached them due to their good name to become a sponsor here rather than just taking anyone that was knocking.
No hesitation to approach Scotts for a members price. tell them you are from here.
Rogue Dung Beetle
6th March 2014, 05:40 PM
Smart like tractor
You cant really go wrong if it is mandrel bent and sits as high as possble between the chassis rails
96 GQ coil/Cab
08 G6eT
6th March 2014, 06:07 PM
Administrator
I was originally put on to them when I upgraded mine. Long before they were on here and can't fault it for the price delivered was even cheaper then local.
I ended up approaching them for sponsorship so the opinions are not biased at at all mate.
Mine sits high up, the mounts were perfect line up and strong.
Sent from my iPhone using Motorculture mobile app
8th March 2014, 02:46 PM
All good thanks people.
looked into various sponsors.
What about the question of ceramic coating?
Ceramic coated cast , v's ceramic coated steel pipe?.
Or dump v's longer engine pipe that incorporates the dump ?.
