6th March 2014, 10:29 PM
Smart like tractor
JJanzon92
Is a T25 a bit to old as well?
Way to small
96 GQ coil/Cab
08 G6eT
6th March 2014 10:29 PM
6th March 2014, 10:33 PM
Oh sounds like the DTS is pretty good. Do you know what turbo its running? And i thought the T28 might have been a bit too small as well and I didn't like how it was welded at all!
6th March 2014, 10:42 PM
Smart like tractor
JJanzon92
Mitubishi tdo5h-16g
96 GQ coil/Cab
08 G6eT
6th March 2014, 10:52 PM
I have also seen Safari Kits as well are they just cheap crappy kits or not too bad?
8th March 2014, 12:38 PM
safari kits are also ok and will do what you want.
The old ones ran a bigger rear housing than the newer ones.
I ran both, both were good, the .63 rear housing was out of puff by 3500, and wouldnt make more than 14psi. But it did it pretty early.
the .82 I had first had a cracked wastegate seat, so was tough to compare
I know have a TD05 18g, and it too is very goood, but with the right pump...
97 patrol coilcab ute. 4" lift, snorkel, 315/75R16 cooper S/T's. and about 200rwhp and some expensive bits and pieces
Organising a group buy for 63% transfer reduction gears, check the link
here
