5th May 2014, 12:18 PM
#51
Patrol Guru
kevin07
unfortunately I was working due to the new and improved light rail not working.
Its all good Kevin. Hopefully see you at the next one. I still have a bit more work to do to get the engine in the GQ.
Cheers,
Rob
Just about to jump into my next Patrol. A 2001 GU II TB45E .
WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
5th May 2014 12:18 PM
5th May 2014, 01:11 PM
#52
Well done guys, a top effort indeed. Try using a trolley jack to lift the gearbox up to line up with the motor also remove the engine mounts and brackets till you start 2 bolts in the bell housing. Also make sure the gearbox is in gear and the clutch is centered, it'll practically fall into place if you've done all that
The Following 2 Users Say Thank You to Alitis007 For This Useful Post:
kevin07 (5th May 2014), rkinsey (5th May 2014)
5th May 2014, 01:45 PM
#53
Patrol Guru
Alitis007
Thanks for the tips Alitis. Will definately remember that when it comes time to install the motor.
Cheers,
Rob
5th May 2014, 06:05 PM
#54
The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
rusty_nail (5th May 2014)
5th May 2014, 06:32 PM
#55
Daily Lurker
Yeah more than happy to lend a hand again but starting at 1 is pretty late.I spent nearly as much time driving to and from your place asi did working on your car.
Also would love to go camping either in the exploder or the troll when it's up and running again. maybe I can show your son what real sport is(rugby union) =P
Nic
The Following User Says Thank You to rusty_nail For This Useful Post:
NissanGQ4.2 (6th May 2014)
