Results 1 to 4 of 4
Thread: surface rust in my gq gutter rails
    Feb 2014
    NSW
    Just wondering what products you have used for surface rust in your roof rails , that seems to work .
    Feb 2011
    Shed
    45 Post(s)
    If its just surface rust rub it back with wet n dry to remove the rust and repaint. If its like mine what looked like surface rust is well ingrained tin worm and only cutting it out and welding in new steel is the only proper fix
  4. The Following User Says Thank You to growler2058 For This Useful Post:
    izzy (27th February 2014)
    Feb 2014
    NSW
    Thanks mate I will have to have a closer look after sanding
    Feb 2011
    Shed
    45 Post(s)
    Mine was caused by the steel roof rack. The rubbers has well n true lay worn off the feet. I saw spots from below but when I looked from above YUK
