23rd February 2014, 02:26 PM
2inch lift with 30mm spacers
Hi guys.
I bought an 98 gu ti with 2 inch tjm lift.
It only done 3000km before I bought it a d I did 2000km with it.
So the suspension is still brand new to replace with a 3inch one.
What I saw from superior engineering are that you can get 30mm spacers for the front and back?
Will that wotk if I just fit the spacers or what do you guys think?
Thank you in advance.
23rd February 2014 02:26 PM
23rd February 2014, 03:04 PM
Smart like tractor
Bugger the spacers. It will be over 3 inch lift, so you will need new drag link, panhards and some form of castor correction or it will handle like crap.
96 GQ coil/Cab
08 G6eT
23rd February 2014, 03:43 PM
Patrol Guru
I have an OME 2 inch lift with 30mm spacers in the back and 20mm spacers in the front,
but my troll has draws and fridge permanently in the back and a roof rack and RTT, so it is always carrying a load,
I use the spacers to compensate for the load not as a cheap lift and for that they are okay.
2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
23rd February 2014, 03:51 PM
I had 3 inch and it is a big mistake running this without allowing for panhards and brake lines and lower control arms and caster correction sway bar connects.
Thought it was fine until I had it up on the hoist and saw how stretched the brake line was and how much the diff moved over and hit my long range tank.
There were plenty of other issues and I have draws and roof rack and fridge. .
Either stick with 2 inch and be happy or budget and do it properly for 3-4 inch.
23rd February 2014, 04:37 PM
Smart like tractor
Bloodyaussie
Good responce....you get a biscuit
96 GQ coil/Cab
08 G6eT
The Following User Says Thank You to Ben-e-boy For This Useful Post:
Bloodyaussie (23rd February 2014)
23rd February 2014, 10:19 PM
Thanks fot the advice mates.
Think I will stick with the 2inch for now and then later get a full 3 inch kit with everything.
25th February 2014, 11:29 PM
I have another question what i thought about.
If you install the 30mm spacers, wont the travel still be determined by the shocks?
You said that the brake lines will stretch and all that?
Wont it still be the same as with the 2 inch lift?
Because it only stretch at it most when it travels or not?
What I have read and seen on the suspension packages are that you can go 3 inch with you standard set up?
Only when you go to 4 inch you need to do the rest?
What do you guys think?
26th February 2014, 07:06 AM
Smart like tractor
Just re read the first post..it answered your question.
96 GQ coil/Cab
08 G6eT
26th February 2014, 07:14 AM
Smart like tractor
For the simple fact of gaining some ground clearence, the steering will be twitchy, the diffs wont be centred properly, it might shimmy under hard breaking, plus a number of little handling quirks.
All that for 30mm of ground clearence........no thanks
96 GQ coil/Cab
08 G6eT
26th February 2014, 07:39 AM
Just read my post again mate.... I had 3 inch with 2 inch coils and 1 inch spacers.
Take it from me a person who has made many a mistake because I did not listen to those that knew better..............
The Following User Says Thank You to Bloodyaussie For This Useful Post:
BigRAWesty (26th February 2014)
