21st February 2014, 11:43 PM
Handbrake light troubles.
So I went mudding the other week, great fun... but since then whenever I turn right the handbrake light comes on and stays on till I turn left. Has anyone had this trouble before?
Life's a garden dig it.....with all 4 wheels.
21st February 2014 11:43 PM
22nd February 2014, 12:24 AM
Check you brake fluid level. Low brake fluid can also cause the handbrake light to come on.
24th February 2014, 05:33 PM
I had the same trouble recently. I found the brake fluid to be low. So I topped it up and light doesn't come on anymore.
NEVER USE A SNATCH STRAP ON A TOW BALL AS DEATH MAY RESULT
GU 2005 Cab Chassis Ex Telstra POD, Set up for Remote Touring and Play
24th February 2014, 06:29 PM
I am he, fear me
X 3 for the low brake fluid warning
1st March 2014, 10:37 PM
Sorry for the late reply and cheers for the responses. It worked I never would have worked that out and I'd still be pulling my hair out. The fluid was still 10mm above the low mark on the reservoir, could this possibly mean there is air in the line somewhere? I have what i would call good braking ability so its never really crossed my mind.
2nd March 2014, 06:31 PM
I am he, fear me
Bigbird91
... its in the (cough cough) manual but, yeah, not exactly intuitive is it.
Sounds like it is coming on a tad early but I wouldn't be fazed by it. If the brakes feel good and you aren't using fluid it's probably OK.
The other alternative is do a bleed I spose...
