Results 1 to 5 of 5
Thread: 2006 GU gear box noise.
    Feb 2014
    Dubbo, NSW Australia.
    Question 2006 GU gear box noise.
    PGTech8
    My 2006 GU DX 4.2Ti has a rattle in 1st and 2nd gear when starting off, only in low revs. I have been told this is normal in a Patrol manual box and is caused by the pressure plate springs. Has anyone been able to cure this with a stronger or different pressure plate or able to shed more light on this problem.
    174 Post(s)
    Same on mine. It is normal.
    581 Post(s)
    It is very common with the td42 and there's a lot of chats about here.
    At low revs I think it's actually the engine and mine harmonics down the drivetrain through gearbox, exhaust, etc.
    Sep 2011
    adelaide
    18 Post(s)
    G`day mate.
    I thin kyou will find its the clutch plate not the pressure plate
    The torsional damping springs in the clutch plate some times become a little weak and thus the rattle
    You can replace the plate with one that has stronger springs or do what I would do and just leave it until a clutch replacement is necessary.
    If your unsure get it checked out at a clutch specialist rather than your local mech
    Legendary happygu's Avatar
    I was always told it was a Harmonic Vibration noise through the drivetrain.....
    No harm usually comes from this noise
    Mic
