Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Oh no....a new issue for my tb45e. Where to look?
  1. #21
    Patrol Guru Evo's Avatar
    Jun 2013
    Lost somewhere in my own head...
    3 Post(s)
    Any closer mate?
    Do you have the little control box on the firewall or near the converter (just looking at my setup) which controls your gas?
    Could be this needs a retune, also could be relays that cut the injectors could be faulty.
    Evo
    Cheers,
    Evo
  2. The Following User Says Thank You to Evo For This Useful Post:
    ozzymalone (19th February 2014)
    Expert 4by's Avatar
    Northern Vic
    Just to eliminate it wont be the maf as the car should still run perfect on lpg as lpg doesn't use the maf. It would only run terrible on petrol. I recently replaced my maf and this was the symptoms.
    Cheers 4by
    Can I put a Holden badge on my Chevy ?
  5. The Following 3 Users Say Thank You to 4by For This Useful Post:
    BigRAWesty (19th February 2014), Evo (19th February 2014), ozzymalone (19th February 2014)
  6. #23
    Expert patrol2.8's Avatar
    Nov 2011
    vic
    My daughters car (astra) was running the same as you described turned out to be a dodgy coil pack
    Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
    WARNING: Towballs used for recoveries,can and do kill people and damage property
  7. #24
    Quote Originally Posted by 4by View Post
    Was just gonna say that... Coil packs worth testing for sure, my old Falcon had similar symptoms and it was the coil pack.
  8. #25
    Expert ozzymalone's Avatar
    Aspley, QLD
    Well when it was all said and done a mysterious man with a golden patrol ute showed up to give us a hand, will post a pick tonight if I get a chance. Was a simple fix in the end as it was the shorter length of intake plumbing between the mixer and the throttle body had worked loose and was letting air into the system. I had already given it a good tug and turn but must admit I wasn't too rough when I needed to be and didn't realise it basically had no hold on the throttle body. Thank you all once again for your input & experience. And big props to the mystery man with the golden ute, you know who you are
    SPEED METAL NEVER WENT AWAY>>>>> ONLY OUR HEARING DID!!!
  9. The Following 3 Users Say Thank You to ozzymalone For This Useful Post:
    Evo (19th February 2014), jack (19th February 2014), lhurley (19th February 2014)
  10. #26
    Aug 2010
    adelaide
    good outcome glad it was an easy fix
    and well done to the golden patrol man
    i hope you gave him a carton of xxxx gold
    OH LEATHER IS NICE
  11. #27
    Expert 4by's Avatar
    Northern Vic
    What a good outcome. Cheap easy fix plus a great forum when others are there to lend a hand. Well done.
    Cheers 4by
  12. #28
    Aspley, QLD
    Was a great outcome! I offered his choice of liquid supplements but he wouldn't accept (gracious bloke that one). Might end up with a gift on his doorstep though.
  13. The Following User Says Thank You to ozzymalone For This Useful Post:
  14. #29
    Jun 2013
    3 Post(s)
    Good to hear it wasn't a major issue.
    Must be almost jumping for joy now and itching to take it for a good long run?
    Evo
    Cheers,
    Evo
  15. #30
    Aspley, QLD
    Quote Originally Posted by Evo View Post
    Evo
    Yeah mate. Will have to get a Gas mob to give the system a looksie so I don't get any more backfiring issues but in the meantime will be giving her a good flogging on petrol. LPG isn't worth it with its' price at the moment anyway. Just have to sort out some long overdue work on the donk (replacing rocker covers, adjusting tappets and give her a proper service) and hopefully be able to scrounge up some dollars for a lift. The stock shock are showing their age and are sagged but the truck still does the easy, moderate stuff with relative ease.
