6th January 2015, 03:55 PM
#191
SG1
Switched to Delo 400, Can get at the Traralgon Caltex Truck stop on princess highway (20L drums), have noticed a bit more blow by in the catch can since using it, seems quiter than when I had the penrite 10-40w semi synthetic but want to change to penrite 5-40w as then it would be all penrite oils in the vehicle or really considering the Castrol RX Super, still not sure which way to go..
I used to sell Castrol a few moons ago now. I still keep in contact with the rep who's been there for donky's. RX Super is not recommended for the ZD30's but the rep was confident that I could use it. But I wasn't. So I have kept on with Magnatec Diesel 15w40. Been using that since day dot and start ups are really quiet and I catch around 150ml of oil in the catch can every 5k service. I did switch to Delo 400 a while back after reading all the hype. After using it for 3 services the motor, used a little oil, had more in the catch can and was noisy on start up. So I switched back and haven't looked back. SCA have the Magnatec on special at nearly half price every now and then on the 10L so I stock up when I can.
One thing you need to remember though is, if you do switch oils, stick at it for atleast two changes, minimum. As different oils use different additives and your motor will react differently maybe to not what you like. But it may settle down, give it a go...
But I wouldn't be using RX super in a ZD30. TD42? Hell yes!
6th January 2015 03:55 PM
6th January 2015, 04:43 PM
#192
anyone use RX Rimula R4x? is it good for zd30?
6th January 2015, 08:45 PM
#193
Ok, so for the ZD30 its Delo 400, Penrite 5-40, or Magnatec 15-40, or Nissan oil..
Was confused as read some were running RX Super or thinking of switching to it soon/next service but have now realised they must be talking about the TD42.
Like the Delo and runs good but same found more in catch can than was expecting and used a small amount, might go the Penrite or Magnatec then, still got 500k's to decide.
02 GU ZD30 Auto, NADS, Setting up for touring and camping, Best thing is the missus loves driving it to..
9th January 2015, 07:22 PM
#194
I'm using Castrol Magnatec 5-30W in my GU9 CRD. I used to use Magnatec 5-40W in my YD25 Navara and it ran beautifully.
The Following User Says Thank You to docp1980 For This Useful Post:
growler2058 (9th January 2015)
9th January 2015, 07:27 PM
#195
11th January 2015, 07:20 AM
#196
Enjoying the trips
Been using Penrite 15W-50. At $72 for 10 litres it's pricey. I had a credit balance of $32 on my Supercheap car so grabbed some yesterday at near half price, schweet.
Macca
The Following User Says Thank You to macca For This Useful Post:
growler2058 (11th January 2015)
11th January 2015, 10:20 AM
#197
macca
How good are those Club Plus Card Hey? One would be mad not to have one.
macca (11th January 2015)
11th January 2015, 11:58 AM
#198
Enjoying the trips
Yeah, Ive probably scored 200 - 300 dollars easy from them.
Macca
14th January 2015, 09:36 AM
#199
14th January 2015, 10:24 AM
#200
trol3.0
was a good read lot of oil testing though
