20th February 2014, 07:15 PM
#11
Evo
I wouldn't have thought they would need changing after that mileage.
Surely there is nothing wrong.
I would keep the new injectors until you need to change them.
Evo
here in Italy, it happened that broke the injectors causing damage
20th February 2014 07:15 PM
26th February 2014, 06:14 PM
#12
How many kilometers in australia to change the injectors ?
26th February 2014, 08:35 PM
#13
ABE
I'm up to half a million..
26th February 2014, 08:47 PM
#14
Westy's Accessories
half a million with zd 30 engine?
26th February 2014, 09:52 PM
#15
ABE
Bahahahahahaha...
Td42.. Sorry to get your hopes up..
Injector companies recommend service injectors every 100 thou.. You will get more, but their performance may drop
27th February 2014, 12:17 AM
#16
Westy's Accessories
Bahahahahahaha...
hahahah I had deluded ...
the injectors I have them already, but I need instructions to replace
27th February 2014, 06:44 AM
#17
Are you talking pressure rail or individual injectors??
Either way you gotta remove all the gear above, cover, if etc instill you have access to the injectors..
You may need a long socket to get them, check the New ones..
Soak em in crc.. The last thing ya wAnna do is snap one...
Try a quick Google search for more detail.
27th February 2014, 06:53 AM
#18
Cut from another forum
" emove intercooler with its hoses
remove buterrfly (the piece attached to intake manifold, in which goes the output from intercooler)
remove rocker cover
unscrew the injector line from the injector you want the remove (you don't need to remove the manifold)
remove injector
these are the main steps, there are also o couple of small things wich has to be disconnected or removed, but you will see them while you're working.“
27th February 2014, 07:50 PM
#19
The Following User Says Thank You to ABE For This Useful Post:
BigRAWesty (27th February 2014)
23rd October 2015, 01:23 PM
#20
How many km before they need changing
