Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Annoying overboost
    Advanced boosh's Avatar
    Auburn, SA
    It's got a brand new genuine maf. Only about 2000k's since I put it in.
    How much does the exhaust factor in? It's the stock exhaust but it's in pretty bad shape.
    When I know it's about to overboost, if I really put my foot into it and max out the dawes valve, it doesn't overboost, or at least takes longer. Taking this into account, I've just gone for a drive where I closed the dawes slightly and opened the needle a bit. I got slightly higher EGTs but they settled quite quickly... I didn't have any limp mode issues, maybe it was just a lucky day, maybe I'm on to something.
    I think it's just going to take me a while to get it right. Like I said, it's a new motor with new turbo and a few other things and it's just slightly different than the previous motor so it's taking a while for me to get used to it...
    Advanced Mud Gecko's Avatar
    Aug 2013
    Darwin NT
    I think you may have your terminology mixed. Overboost suggests (for example), if you have your dawes set at 14psi, when you accelerate you 'overboost' and hit 16/18 psi before it settles at 14. When limp mode happens you will have max 10psi with virtually no acceleration until you lift off the throttle then power will return.
    Limp mode in my experience is a combination of too high MAF voltage and/or too high boost. If you have ECUtalk its easy to see it happen.
    Overboost on the other hand is fine tuning dawes and needle. I still get a slight overboost on mine but I like the quicker spool-up rate With my setup I will 'overboost' to 19/20 under WOT then settle to 17psi.
  4. The Following User Says Thank You to Mud Gecko For This Useful Post:
    boosh (17th February 2014)
  5. #13
    Advanced critta11's Avatar
    Feb 2014
    The car could have collapsed causing back pressure and stuffing everything up.
  6. The Following User Says Thank You to critta11 For This Useful Post:
  7. #14
    462 Post(s)
    ^^^^ Eh?
    Also the MAF still could be faulty. Unlikely but it does happen. I have sold around 100 OEM MAFs in the last 12months and only have had one faulty one. So while its not common, it does happen. You don't have your old MAF to try? Just for the sake of trying...
    critta11 (17th February 2014)
  9. #15
    Aug 2013
    Darwin NT
    I think Critta may mean 'cat', which is entirely possible and a great excuse for a shiny new exhaust
    Boosh, is your EGR blocked?
  10. The Following 2 Users Say Thank You to Mud Gecko For This Useful Post:
    boosh (17th February 2014), critta11 (17th February 2014)
  11. #16
    462 Post(s)
    Lol yeah.
  12. #17
    Auburn, SA
    Quote Originally Posted by Mud Gecko View Post
    Yeh my EGR is blocked.
    That's an interesting thought about the cat... The previous owner fixed/welded it up at some stage. I do plan on a new exhaust, just don't have the funds yet. Is there a way I can check that?
    I might put the old maf in to test it mudski.
  13. #18
    Feb 2014
    ^^^^ Eh?
    Yeh I did mean CAT haha my bad
