12th February 2014, 10:13 PM
Patrol Guru
Power antenna with aftermarket head unit.
G'day folks,
I'm looking at taking out the POS factory head unit and replacing it with a single din head unit and a single din UHF radio.
I was in the car stereo joint today and the guy there reckons that the power antenna will no longer work as it does now, he reckons it will only go to the full mast position and won't be able to go to the half mast position.
Im not sure if he knows what he's on about or not.
Can anybody with an aftermarket head unit let me know if their antenna still works as it originally did?
Cheers, Paul.
12th February 2014 10:13 PM
12th February 2014, 10:23 PM
The Mad Ozzy
Rubbish, I don't think the guy knows. You will need an adapter from the OEM 2 plug to a single. Done it with mine and the power aerial works fine.
www.swat4x4.com
12th February 2014, 10:32 PM
Patrol Guru
oncedisturbed
Cheers mate that's what I thought. I can't figure out how it wouldn't work. Don't think I will be buying anything off that shop.
The Following User Says Thank You to firm351 For This Useful Post:
oncedisturbed (12th February 2014)
13th February 2014, 12:50 AM
I am he, fear me
Bullshit... Lost count of the number of vehicles that I have done that too including my latest baby on the weekend and the power antenna works same as factory.
Aerpro make an Iso to Patrol harness altho depending on model and age you may need a diversity adapter harness for the antenna only because the plug is different.
The adapter harness cost about $15 from supercrap, repco, alberts or wherever. Worst case is you may need a second harnes to go from Head Unit to Iso depending on manuf so that is another $15 or so for a "plug and play" solution
13th February 2014, 01:06 AM
Patrol Guru
the evil twin
Thanks mate, when old mate told me about the antenna I thought that can't be right then I asked him about iso adapters and he didn't seem to know bugger all about them that's when I realized he knew bugger all about what he was selling.
Go to a proper car audio shop you expect to see someone that has a bit of a clue.
14th February 2014, 06:52 PM
The head unit has nothing to do with the half mast function. This is controlled by the aerial switch in the dash and the electric aerial motor.
As long as your head unit has the aerial output it will work fine.
The Following User Says Thank You to Yendor For This Useful Post:
firm351 (14th February 2014)
14th February 2014, 07:05 PM
Mine kind of works. It now goes up even if im listening to a cd or bluetooth. Anyone know how to stop this?
14th February 2014, 07:22 PM
Don't know why yours does this but you can put in a switch to cut the power to the antenna and then it will go down when you hit the switch. I had to do this to mine with the last head unit as when out in the bush I would have the radio off and when I would select reverse the radio would switch on for the camera and the antenna would come up. My new head unit this does not happen and the screen only turns on when I select reverse.
The Following User Says Thank You to mudski For This Useful Post:
14th February 2014, 07:27 PM
Patrol Guru
Yendor
Cool, thanks for that mate thats how I thought it would work but old mate at the stereo shop threw me off when he told me it would no work.
It gives me the sh!ts when the people in the specialized shops still don't know what they're talking about.
Yendor (14th February 2014)
14th February 2014, 07:30 PM
nickpeacock36
It sounds like a problem with the head unit.
