Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: gq speedo problems
    Jun 2020
    Is there anyone in Darwin that can fix instrument cluster in a GQ 1997 patrol?
    80 Post(s)
    Welcome to the forum. http://www.nissanpatrol.com.au/forum...-Introductions
    A few years ago, there was a bloke online that would fix Patrol clusters on a swap over basis. You'll have to search to see if he's still going.
  4. The Following User Says Thank You to mudnut For This Useful Post:
    GRobson (13th June 2020)
  5. #13
    Jun 2020
    Found this site, none currently in stock. Cheers for the welcome.
  6. #14
    80 Post(s)
    What is the problem with the unit?
  7. #15
    Exactly what GQ TANK has said 👌🏼Had the same issue and repaired by a gauge specialist for about $200 approx.
  8. #16
    Banging the top of the dash “usually” fixes the issue...BUT...mine got gradually worse and driving around with no speedo was stressful (speed cameras everywhere lmao). I ended up finding a gauge specialist and was a relatively cheap and easy fix. Also banging the dash so many times i broke one of the mounting brackets so just a caution.
  9. The Following User Says Thank You to The Survivalists For This Useful Post:
    mudnut (3rd July 2020)
