15th February 2014, 09:21 AM
#11
A couple of things to check then.
Has it got castor correction or drop boxes??
If you look at the radius arm bushes are they offset in the Bush? Or plates hanging Off it?
Or do your radius arms attach to a box below the chassis??
15th February 2014 09:21 AM
3rd March 2014, 01:36 AM
#12
Hey sorry, its been ww3 in my personal life lately so sorry for the late reply. I did the damper and the wabbles all gone, with only the occasional ever so light shimmy in the steering wheel assuring me the band aid theory was right. I checked the radius arm tonight and where it mounts to the chassis it seems to have one hell of a huge bush either side, but thats the best i can see in the dark and wet. Ill take some pictures tomorrow of the underside. I do remember when i did inspect the radius arms a few weeks back that all bushes looked to be new, and the suspension is older so I would assume its got caster correctors, but to assume is to make an ass out of you and me so Ill take some photos tomorrow. I do think the rear swaybar links have not been done though, so maybe the previous owners been doing a dodgy.
Cheers and sorry again, I assure you ill be on here more from now on and will take your advise openly
Rob
3rd March 2014, 03:17 AM
#13
3rd March 2014, 03:36 AM
#14
Engine wise I cant really complain. She always starts, even with the stereo going for a while on accessory. Just needs a freshening up. It looks to have been a heavy tower and then went to a kid who bushed it hard. Still pulls off the lights and surprises you how quick it can move for a big girl but she hates hills if your not on top of gear selections. I think the pipe from the manifold to the cats maybe perished, but that will be done with the extractors and hopefully high flow cat. Its a bit funny on 2nd when cold or if hard shifting, but thats to be expected of a tower. Clutch seems fine but I have plans for a fluid flush very soon just in case. Nissan go on about how strong the 5 speed was, so it should hold for now. If the box or engine goes, Id like to sat a replacement tb42e and 5 speed would go back in but the lure of a v8 is tempting. All in the future though. With the work I can see thats been done suspension wise it obviously had some money spent on it, but it needs more. Im going to recover the rear wheel well trims and remove the 7th seat hole thats created either side. Ill also redo the rear barn door trims. It has to be done in a neat yet rugged way. Ive left the factory barn door speaker covers on as they are resilient. Function, practicality, max efficiency/power and still be able to be slept in in the bush if needed is what I am after.
3rd March 2014, 03:42 AM
#15
With the reverse cowl, I plan to have it open from the top to half way down windscreen side to extract heat, but also to not allow much water to enter unless submerged. Is it best to cut the bonnet completely around the inner sides of the cowl, or would it be best to only run a hole down near the front of the cowl to catch the air rebounding off the firewall?
3rd March 2014, 04:13 AM
#16
Oh forgot to mention, the stereo setup cost me a total of $52. The stereo came out of the mq, so did the 6" pioneers. The JVC cost $20 and was bought by my neighbour as a thanks for fixing his car, the phillips I have had now for almost 10 years, the fusions cost $10, the Sub came from the Mq, the box timber cost $12 and the rest of the box was leftovers stored, including 3 coats of undercoat enamel. The Audioline amp cost $30, but I also got a pair of Jaycar response 6x9 kevlars thrown into that deal for the magna. All wires are oversized and cam from either a friend in the trade for free or from my collection.
