Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: front left wheel bearing
    Jun 2013
    Woodford
    How do I attach photos
    Jun 2013
    Woodford
    I have photos but not sure how to post
  4. #13
    Jun 2013
    Woodford
    What do u think I have to replace
  5. #14
    Jan 2013
    Thats fair cactus. Studs nuts and discs.
  6. #15
    Legendary happygu's Avatar
    Aj,
    The studs, nuts and rim will definitely need replacing.
    The hub may be cosmetic damage only, which will be fairly easy to tell once you remove the rim. If it is cosmetic, then it is up to you whether or not you replace it
    Mic
  7. #16
    Jan 2013
    ahh thats the rim. yeh its stuffed haha
  8. #17
    Jun 2013
    Woodford
    Happygtu how would I know the hub is cosmetic or not
  9. #18
    Quote Originally Posted by aj_vmax View Post
    Aj,
    Attached is a picture I found of the Main Hub itself, and you can see that the Auto/Manual Selecting hub has been removed form where it is bolted to the main Hub Assembly itself, and your damage is confined to the outside edges of the Main Hub Assembly.
    This will still be fairly strong, as there is a solid ring of metal on the inside edge of the bolt holes, as well as the remaining metal on the outside edges of the Main Hub.
    If you are OK with it the way it is, you could grab another hub, and change this over when the bearings are getting repacked, as this will save you a little in labour costs...
    Mic
  10. #19
    Jun 2013
    Woodford
    Thanks guys just replacing the studs
