Results 1 to 3 of 3
Thread: cardan shaft !!
    Question cardan shaft !!
    hello everyone
    i decided to change the rear coil springs.. I went today to change them to (OLD MAN COIL SPRINGS) and the guy who works there said there is only one size springs 3cm since its a hardtop patrol, BUT the problem is what i heard about if i it gets higher from the rear i might hear some noise coming from the cardan shaft !!
    is that true guys?..
    by the way,it's a new patrol (automatic transmission) never changed anything in the car
    thanks
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Bump for mk17
    Patrol Guru Evo's Avatar
    Jun 2013
    Lost somewhere in my own head...
    Quote Originally Posted by mk17 View Post
    hello everyone
    thanks
    30mm (3cm) I'm guessing is how much higher the springs will make it sit?
    If this is so, should be fine.
    That's only just over 1 inch.
    Should be able to go at least 2 inches with no issues of changing anything (in majority of cases).
    Evo
    Cheers,
    Evo
