Results 1 to 5 of 5
Thread: Icom Pro400 Programming Software
    Expert altech's Avatar
    Nov 2011
    Bittern, 3918, VIC
    Hi Guys , hope this programming software is useful to some people, it's software I got from Icom pro400 Forum many years ago now which I found useful, eg setup a password buttons on the face of radio , having private channels on the side and listing to Emergency Services that are still using UHF .
    Connect link cables you can be found on Ebay around $25 buck. regards Alex
    p.s. : must use serial number that in zip file under the heading "Code"
    Icom Pro400 Zip File
  2. The Following 8 Users Say Thank You to altech For This Useful Post:
    AB (2nd February 2014), FNQGU (2nd February 2014), MudRunnerTD (2nd February 2014), NissanGQ4.2 (2nd February 2014), oncedisturbed (2nd February 2014), P4trol (2nd February 2014), Ronin (2nd February 2014), the evil twin (2nd February 2014)
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    15 Post(s)
    They are a great bit of kit, but not the easiest or intuitive to use. I like mine as it feels more solid than the GME but there are so many functions that it is easy to get lost with it if you don't know exactly what you are doing. Thanks for the file.
    Had a beaut GU with 6.5 Chev TD, but sold the soul and now driving a 79 series dual cab. Yes, a Tojo on the Patrol Forum! Also having fun trying to build the ultimate Expedition Grade storage box.
    www.openskytouring.com
  5. The Following User Says Thank You to FNQGU For This Useful Post:
    altech (2nd February 2014)
  6. #3
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Great units and very handy program. I have just recently programmed mine and now wondering why I didn't have a play earlier I added the 80 narrow band channels to a private bank so I can use it as either a 40ch or 80ch depending on who I am with and also on the 80ch bank I have selectable 1w 5w or 25w output power on the front of the unit with the press of a couple of buttons. I also have the 80ch CB bank file if any want it PM me. They are available from various forums around too.
  7. The Following 2 Users Say Thank You to sooty_10 For This Useful Post:
    altech (3rd February 2014), FNQGU (3rd February 2014)
  8. #4
    NT
    Post it up, Sooty!
  9. The Following User Says Thank You to P4trol For This Useful Post:
  10. #5
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    15 Post(s)
    Good set up Sooty, I like the idea of being able to select 25W on occasion too.
  11. The Following User Says Thank You to FNQGU For This Useful Post:
