1st February 2014, 04:51 PM
Patrol-range rover
Does anybody know if range rover wheels fit on a patrol
1st February 2014 04:51 PM
1st February 2014, 04:56 PM
No Range Rover use 5 stud pattern Patrol use 6 the same as landcruisers , pajera and Jackaroo
All are not interchangeable though
1st February 2014, 05:17 PM
Cheers I knew that pajero and hilux would wasn't sure about range rover
1st February 2014, 05:18 PM
What do you think about a 89 range rover any good
1st February 2014, 05:26 PM
In what sense?
In terms of comfort they are very good, and they are excellent off road even in stock form.
I'm unsure, but I think the 89 model may have a viscous centre diff, which is not as effective as the older style mechanical locking diff.
And also, the V8 note is nothing short of glorious.
The 89 should also be an EFI model, this was a big improvement on the old carby setup.
Personally, I love old Range Rovers. If I was not on my P plates, I would have one in a heartbeat.
Downsides are they are thirsty, not as strong as a Patrol in the driveline, they tend to develoo oil leaks and they can be unreliable, however regular proper maintenance can go a long way to resolving many issues.
Owned nothing but SWB Patrols
'84 Red MK SD33T SWB, 31" A/T's, bullbar, spotties
'86 Silver MK L28 SWB, 31" muddies, bullbar, steel canopy
'86 White MK SD33T SWB, 31" A/T's, ARB bullbar, spotties, steel canopy
'85 Silver MK SD33 SWB 31" A/T's, bullbar, light bar, 2" lift, snorkel
1st February 2014, 05:28 PM
Depends what you want it for. I have heard that their electrics play up a bit, but have not been told of any one instance. I think they use the same V8 as the discovery, but don't quote me on that. My sister owns a V8 disco and has had an excellent run with it.
1st February 2014, 05:31 PM
Mate I love rangies 89 is still a mk 2 I think , look for the lse model its longer than others
First motor was an alloy 4.4 same as P76 then they went to a 3.9 been a while for me
1st February 2014, 05:36 PM
threedogs
First moyor was an alloy 4.4 same as P76 then they went to a 3.9 been a while for me
First motor was a 3.5 V8.
I think it is just a smaller version of the 4.4, as was the 3.9
The 4.4 is a common swap though.
1st February 2014, 05:42 PM
yeah I;m all excited first motor was 3.5
4.4 was a common replacement
3.9 not the best motor around,
there are a few early diesels kicking around.
stay away from the air suspension at $6K a corner its $$$ to repair.
As mentioned the electrics let them down, but they are smooth to drive,
took one to Cape York in 1983
1st February 2014, 06:34 PM
Someone offered me a 89 rangie 4" lift cb brush bars 3 months reg for my 86 mq swb duel fuel dual battery 4 months reg
