Results 1 to 10 of 11
Thread: 1992 GQ 4.2 petrol Wagon,
    May 2011
    Hi All Tony T here, the above wagon is Auto, Pulled up in drive working great, turned it off, and wouldn't start in morning , ignition lights all came on, made all the right noises, ( its petrol gas,) but no nothing, lights on dash don't even dim when key turned, New Starter fitted, battery ok fuses ok the ones I can find, all wires seem tight and don't move when wriggled. thoughts please.
    HEY ALL THANKS FOR YOUR IDEAS FOUND THE PROBLEM
    THE IGNITION BARREL IS BUGGERED, SO IF YOURS DOESNT WANT TO START AND YOU HAVE NO NOTHING TRY LOOKING THERE FIRST,, regards Tony
    T
  2. The Following User Says Thank You to Tonyt For This Useful Post:
    Bob (13th February 2014)
    Have you tried clean the inside if the terminals and artery posts? Might seem like a silly question but the exact same thing happened to me on Sunday. I check everything but untilI I had enough and called the RAC, 2 minutes later, clean terminals and posts and away she starts. No issues since.
    Advanced warner01's Avatar
    Jan 2014
    morphett vale
    what about the wires on the back of starter. the ign wire hasnt fallen off or broken maybe?? have you tried roll starting it to make sure its only the starting system thats not working.
    Patrol God Stropp's Avatar
    31 Post(s)
    Main engine fuse is in the engine bay, check that after you clean the battery terminals as clunk says.
    Quote Originally Posted by Tonyt View Post
    T
    Forgot to ask, is it trying to turn over, or are you just getting a click?
    May 2011
    No I haven't will do that now, thanks for the tip,
  9. #7
    May 2011
    put new starter on checked all wires have power to starter, cant roll start as is auto, will chase wires again, power to ignition, and to starter
  10. #8
    May 2011
    Only the noise of the gas and normal noises when turn key on, no click or anything from the starter, when the key is turned nothing happens at all, not even the dash lights dim a little
  11. #9
    May 2011
    not turning over nothing happens when u turn the key just found a buzzing noise in the transmission, don't know why, but buzzes when u turn key on
  12. #10
    Tried starting in neutral?
  13. The Following User Says Thank You to Clunk For This Useful Post:
    Avo (12th February 2014)
