30th June 2010, 02:32 PM
#11
Advanced
just went out and bought 3 sets of 55w HID's 4300k for my roof lights and also for the main headlights and a set of crystal lens as well, gota love ebay!
30th June 2010 02:32 PM
30th June 2010, 02:42 PM
#12
GQ4.2
You do indeed......... If you wouldn't mind Putting some pics up when you've completed the job & gave a bit of a run down on how you went about it for those who haven't done this before but would love to give it a go themselves that would be great.
Cheers mate & thanks for the post
Paul
30th June 2010, 09:58 PM
#13
Advanced
no probs sure will, anything is better than the standard GQ headlights
1st July 2010, 09:46 PM
#14
Just put a Lokka in the front of the Patrol + 3" exhaust and 2" suspension.
However I have an intermittent dull knocking from the front when turning.
Happens about once a week or so. Very annoying.
Have read it could be the new springs moving.
Maybe pads under them could be the answer?
Thoughts anyone before I go back to the supplier?
Damian
1st July 2010, 09:59 PM
#15
Moderator
Chambo Off to Work We Go
Damian
What sort of lokka did you put in? if it is an auto lokka (lock right or similar) i think that they will make a noise during turning and they will be "engage - disengage - engage - disengage" around the corner. your power steering will hide it to your steering wheel but could easily be the problem.
If it is then you have no problem and just something to get used to. Hope it is.
I would think if it is your springs not seating properly then they are more likely to make noise over a bump rather than around every corner.
Hope that helps and i dont throw you off.
cheers mate
1st July 2010, 10:04 PM
#16
MudRunnerTD
cheers mate
Yep, like what mudRunner said. You could also try to turn the springs a bit. My mate had this problem and just by turning the springs a bit it stopped straight away.
Could be worth a shot if nothing else works.
1st July 2010, 10:09 PM
#17
Yes an auto locker (Lokka brand).
But when I had a play with that about 3 weeks ago I heard the clicking noise it makes - very faint.
I knew about that from reading about them in 4WD action Mag and the product spiel.
The noise when turning is louder and you wouldn't call it a click.
That is why I don't think it is the lokka.
Also haven't had it in 4wd / hubs engaged for the last 3 weeks either.
It is odd that it is so intermittent too.
Read about the spring pads on another forum, which is what got me thinking this is what it could be.
Probably wasn't a good idea getting the 3 mods done all at once, but seemed expedient to do it that way.
Maybe a trip back to the supplier might be needed.
2nd July 2010, 09:29 AM
#18
Damian
I have a 2" lift in my GU and it makes a clanking sound, which is coming from the sway bars.
Did they adjust the lenght of the sway bar pins after the lift?
Just a thought !
2nd July 2010, 10:03 AM
#19
KBOOBI
Just a thought !
x2 Good point KBOOBI I was racking my brain trying to think what I did to get rid of a similar noise & that was it....... I think you call that....Shazann......lol
Paul
6th July 2010, 12:29 PM
#20
Advanced
DX grunt
DX grunt. See signature for details.
Did you put this pod in yourself Rossco?
Wouldn't mind getting one of these for my tray but only covering the front half of the tray....Looks real neat and secure.
