Results 1 to 6 of 6
Thread: adding turbo to a td42. where do you run the oil/water lines
    Advanced
    Feb 2013
    Hello
    Im adding a turbo to my na td42. Im wondering if people could post a few pics of where you have run your turbo water/oil lines?.
    Ill be running the oil drain to the sump but id like to know where you guys run the feed and return for oil and water.
    Pics would help. Maybe even a link to a line kit
    North brissy
    The DTS kit comes with all of that and can be had for about 3k with absolutely everything you need. Also there is AB's turbo thread which you could search for.
  4. The Following User Says Thank You to nissannewby For This Useful Post:
    Drewboyaus (28th February 2014)
  5. #3
    Advanced
    Feb 2013
    Not keen on buying the whole kit seeing as I have the turbo and manifold already.i just want to know where people tap into to get the oil and water
  6. #4
    581 Post(s)
    Have a read of the below mate, I did a DIY when I put mine in with pics, etc.
    http://www.nissanpatrol.com.au/forum...ead.php?t=4973
  7. #5
    Advanced
    Feb 2013
    Thank you for that
  8. #6
    Advanced
    Feb 2014
    Grub screw near the oil cooler/ tap the heater lines
