Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: !!!!urgent!!!! Will gq brake booster fit mq-mk
    Benarkin QLD
    Dont be shy,keep askin the silly questions
    I just wish we had the advancement of the interweb many moons ago
    Sheeet i woulda save a gazzilion $$$ and saved all those skinned knuckles
  2. The Following 2 Users Say Thank You to MQ MAD For This Useful Post:
    MS29431 (29th January 2011), patch697 (29th January 2011)
    Banned
    Quote Originally Posted by MS29431 View Post
    Sorry about the stupid qtn's but if you dont ask you dont know, ms
    The only stupid thing to do is not ask, you have a wealth of great members here & all there knowledge to tap into.
    This forum prides itself on its sharing of information & the friendly lay back atmosphere needed so members like yourself can feel comfortable in asking any & all types of questions.
    Remember a question is only something you don't already know the answer to & when it comes to Patrols & off read adventuring what better place to ask.
  5. The Following User Says Thank You to patch697 For This Useful Post:
  6. #13
    Expert MS29431's Avatar
    Nov 2010
    NTH EAST SUBURBS MELBOURNE
    Well as i say to people there's no shame in not knowing somthing cause if you ask. then you know, and thats when you learn!
    Thanks again guy's. ms
  7. #14
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    61 Post(s)
    $165 from repco for pbr master cylinder,
    its worth it saves buying a wreakers job just to have the same thing happen again 6mths later..
    Just gotta wait till its in on tuesday...
    Hey mate as everyone else has said, there is no such thing as a stupid question on this forum, that is one of many things that makes us different to all the other forums and we are proud of it.
    If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
  8. The Following User Says Thank You to Woof For This Useful Post:
  9. #15
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    Don't throw away old master cylinder as you can rekit them for much less than new one, it's not hard.
  10. The Following User Says Thank You to Finly Owner For This Useful Post:
  11. #16
    Expert 89GQ's Avatar
    Adelaide South Aus.
    Not a stupid question was there any fluid inside the car (footwell) where the rod comes through? Mine done it aswell,on a GQ though! Booster was fine just needed new master cylinder and it was fixed. One thing i done was put some fluid in the master cylinder before fitting, Makes bleeding easier, and the manual said it. Good luck, $165 sounds about right for the master cylinder.
    89 GQ TD 42
  12. The Following User Says Thank You to 89GQ For This Useful Post:
  13. #17
    Nov 2010
    I will rekit the booster thanks for the heads up,
    and luckily there is no fluid leaking to inside cabin... lucky
  14. #18
    Benarkin QLD
    89 GQ,
    Yep thats a handy tip adding the fluid in the master cylinder pre fitting
    You can actually pre bleed the master cylinder before fitting as well
    Saves ALOT of air getting into the brake system
  15. The Following 2 Users Say Thank You to MQ MAD For This Useful Post:
    89GQ (30th January 2011), MS29431 (4th February 2011)
  16. #19
    Adelaide South Aus.
    Quote Originally Posted by MQ MAD View Post
    89 GQ,
    Yep i done it on my clutch master as well and does make bleeding easier and quicker, Just leave the blue or red tabs in where the lines hook up and put a rag under when attatching brake lines.
    89 GQ TD 42
  17. The Following User Says Thank You to 89GQ For This Useful Post:
  18. #20
    Nov 2010
    Thankyou Guy's For Help With My Master Cylinder
    Thanks heaps for all your tips and tricks on changing my master cylinder,
    I will re-kit my old one for a backup or whatever,
    I even went to the extent of bench bleeding it before we fitted it,
    All went well now it stops like its never stopped before...... almost stops too good
    Thanks. mike
    Someone's Gotta Break 'Em... So It Might As Well Be Me!!.
