Results 1 to 6 of 6
Thread: Need Info for a Zexel pump off Td42 Blacktop also AXT turbo.
    Feb 2013
    Iceland
    I recently bought a Td42 Blacktop with a broken head to do a injection pump swap (have a inline pump). I was told it was a '94 model and it has a Zexel VE type injection pump. I'm trying to get some information about this pump, plunger size and if it can be used for turbo modification without having to send it to the diesel shop. Also what should the crack pressure be for the injectors originally and what should they be set to when torbo'd? I have an AXT water cooled turbine and have been using it for a year now with not so good result because the inline ip can not be tuned to give more fuel. Does anyone know how much boost is safe for this turbine? Thanks in advance and cool greetings from Iceland!
    Injestion pump number:
    365 J793173
    Pump no. 104660 - 4300
    Sticker in the front:
    16700 50N00
    104760 - 4300
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    no idea mate but hopefully someone will jump on and be able to help.
    GQ Snorkle Lockers front n rear
    Feb 2013
    Iceland
    Been googling around and can't find a webpage where i can see information about Zexel pumps using pump numbers.
    Apr 2015
    i got same probleme here on tunisia i juste changed the original plunger -(6.5mm) too a (7.5mm) and did som stup to fix the gazoil flow !
  6. #5
    Jul 2015
    If you need any part for the ZEXEL pump or diagram, let mi know! I'll send it to you.
  7. The Following User Says Thank You to galme For This Useful Post:
    GQtdauto (12th November 2017)
  8. #6
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    I found it hard to get any real info on this pump or a proper diagram when I replaced the top O rings that were leaking .
