17th January 2014, 07:14 PM
wont shift into 4x4low or high :mad:
wont shft into 4x4, you can move the gear stick and it disengages drive but wont shift into 4 low or high and the green 4x4 light on the dash doesnt light up. help appreciated
gu st 2.8 1999 turbo diesel rd28
17th January 2014 07:14 PM
17th January 2014, 07:25 PM
Jump under the bus and check the lever pin is still attached to the arm On the transfer box.
The gear stick has its own gate which forces to downward movement so it will feel normal even if the connection is broken.
20th January 2014, 03:16 PM
thanks westy ill let you know how i go
20th January 2014, 03:30 PM
have you tried rolling along slowing to shift on the fly
29th January 2014, 02:47 PM
threedogs
thanks threedogs, yeah i have to no avail. should have it on the hoist this weekend. hopefully its just that pin
29th January 2014, 04:09 PM
My troopy was like that and ended up being a bracket underneath not allowing it to engage.
and when it was in gear popped out now and then ,not good in steep counrty
31st January 2014, 12:18 PM
yeah thats a bit dangerous. it never popped out when it was working.
31st January 2014, 02:25 PM
Whats the oil in the transfer case like? Might need a changing...
