Results 1 to 8 of 8
Thread: wont shift into 4x4low or high :mad:
    Oct 2011
    wont shft into 4x4, you can move the gear stick and it disengages drive but wont shift into 4 low or high and the green 4x4 light on the dash doesnt light up. help appreciated
    gu st 2.8 1999 turbo diesel rd28
    43 Post(s)
    Jump under the bus and check the lever pin is still attached to the arm On the transfer box.
    The gear stick has its own gate which forces to downward movement so it will feel normal even if the connection is broken.
    Oct 2011
    thanks westy ill let you know how i go
    have you tried rolling along slowing to shift on the fly
    Oct 2011
    thanks threedogs, yeah i have to no avail. should have it on the hoist this weekend. hopefully its just that pin
    My troopy was like that and ended up being a bracket underneath not allowing it to engage.
    and when it was in gear popped out now and then ,not good in steep counrty
    Oct 2011
    yeah thats a bit dangerous. it never popped out when it was working.
    462 Post(s)
    Whats the oil in the transfer case like? Might need a changing...
