18th January 2014, 08:35 AM
#21
the evil twin
Because
a) EGR blocks are illegal and
b) they screw with the ECU and will illuminate the check engine light with P0401 fault codes
but...
there is NO WAY I would be without an EGR block on any ZD30 Patrol I owned
Why does it throw the code?? Didn't think there was an egr sensor??
18th January 2014 08:35 AM
18th January 2014, 10:09 AM
#22
So get the plate, whack it in and that is absolutely all?
Sounds and looks easy enough.
I though i read somewhere that it effete the boots levels or something.
Also having a little problem with my diesel gas conversion.
The gas is full, its turned on but it does not seem to be mixing and working.
Where would i take my car to get this gas system looked at?
18th January 2014, 10:42 AM
#23
You will need to find a place that does Diesel/gas conversions.
may be just a gas conversion centre may be able to help
Check wires to the switching solenoid for power
18th January 2014, 01:40 PM
#24
try united fuel injection in redcliff mate.
19th January 2014, 01:10 AM
#25
I am he, fear me
Leighw85
Your correct, it is a fiddly job but anyone can do it and, yes, it changes the Turbo behaviour.
I adjusted my Turbo as per the Nissan Bible and she has been good as gold ever since (did EGR about 70,000 K's ago)
There are reports that the early ZD30's won't throw an error code. I don't know if that is true or not as I haven't owned one.
The later ones certainly do and the code is P0401 "Exhaust Gas Recirculation flow insufficient"
If yours doesn't the thats tickety boo, if it does then you have a few choices to "fix" the check engine light coming on...
Some people drill a small hole in the plate (I think 10mm but could be wrong).
If you have a CRD you can clear it with a Scangauge
You can just ignore it and hope it was the EGR block
19th January 2014, 08:25 AM
#26
Leighw85
It does affect boost levels if fitted alone.
You have fitted the dawnes valve so this should still hold its setting.
the evil twin (19th January 2014)
19th January 2014, 03:42 PM
#27
I am he, fear me
Sorry Westy... it was you that mentioned some ZD's not throwing error codes and I didn't acknowledge that earlier.
Onya for posting that up mate, I wasn't aware of that only having had a CRD in the 3 litre.
Totally agree that the Dawes will hold boost level before and after however the Needle may or may not need a tweak to get the desired spool rate.
Again I base that on having to adjust the actuator on the CRD's so could be wrong... again...
BigRAWesty (19th January 2014)
19th January 2014, 04:23 PM
#28
the evil twin
And I'm only going on what I read lol.
So really we should be the last 2 to listen to..
19th January 2014, 08:13 PM
#29
Cheers fellas.
Ill get this sorted when i get home from work in a couple of weeks.
There is power getting to the switch of my diesel gas as the lights are on it saying its full.
Looks like i will need to take it to United in Redcliffe. Thats the place that keeps popping up in my searches also.
20th January 2014, 03:55 PM
#30
Just 2 things you might want to consider:
1. Bigger intercooler with attached fan.
2. If your current glow plugs have done about 80,000K get them physically checked or just replaced.
