17th January 2014, 08:42 PM
#11
Dribble Master
Leighw85
The mechanic i take my Patrol to is a very well known place in Perth and they were really hesitant on blocking the EGR?
Im not sure why......... Any ideas?
I
Hey Leigh, long time no see on here bud, hope all is well. Blocking the EGR it isn't quite legal, so I'm guessing they wouldn't want to be found out, specially if the mechanics are who I think they are.
17th January 2014 08:42 PM
17th January 2014, 09:06 PM
#12
Clunk
Hey mate. I ain't been around to much, so bloody busy hey. Have been a way a while with work, now I can finally start planning a trip with so,em time off! How you been?
Is the EGR easy to myself? Looks like a pretty straight forward piece to put on!
So this is an important par to add?
17th January 2014, 10:17 PM
#13
Dribble Master
Leighw85
Yeah not to bad this way mate, Mudski I believe is the man to ask about the EGR plate, not being a diesel owner I haven't paid to much attention but I believe it stops all the EGR gunk going into the intake and clogging it all up (or something like that).......... Bucket loads of info on it in here somewhere.
17th January 2014, 11:04 PM
#14
I am he, fear me
Leighw85
Because
a) EGR blocks are illegal and
b) they screw with the ECU and will illuminate the check engine light with P0401 fault codes
but...
there is NO WAY I would be without an EGR block on any ZD30 Patrol I owned
The Following User Says Thank You to the evil twin For This Useful Post:
BigRAWesty (17th January 2014)
17th January 2014, 11:20 PM
#15
So it's a pretty important mod?
Doesn't it raise your EGT's also?
Is there any adjustments that are needed once it's installed. To anything? And how easy is it to fit?
18th January 2014, 12:14 AM
#16
Leighw85
From reading about the zd30 engines the egr system is one if the main causes of blowen engines.
It cakes the intake and head with soot which in turn creates uneven hot spots and then it's down hill from there.
To do it properly you need to block the egr, 2 bolts which can be stubborn so prep with the wd40 is recommend, slip the plate in and refit pipe.
But also you need to remove all the crap which will be plastering your intake manifold, intercooler and intake pipes.
So if you have the time strip your intake Off and give it all a good clean out..
18th January 2014, 05:47 AM
#17
So just say I unbolted and fitted a EGR blocking plate and bolted it back up. ( is it really just that easy? )
Or is there boosting issues I have to sort or anything afterwards?
18th January 2014, 08:02 AM
#18
Block it at the top of the motor too, yes very easy to do remove engine cover,
you'll see it on the LHS of motor un-do 2 x 10mm bolts, place the plate behind
with the OE gasket and tighten.
18th January 2014, 08:24 AM
#19
as you are in perth talk to the ferret he sells them and is a member here
http://www.nissanpatrol.com.au/forum...659-the-ferret
OH LEATHER IS NICE
18th January 2014, 08:32 AM
#20
Yea that easy to do.
To get best outta the patrol
A re tune could be on the card, but it will run fine as is. You may notice a small power increase due to drawing 100% fresh air.
