15th January 2014, 09:45 AM
15th January 2014 09:45 AM
15th January 2014, 09:53 AM
spraying belt grip could cause some issues.
I was led to believe these 4.2s were bulletproof, could it be lack of maintenance.
Got me stumped
15th January 2014, 09:56 AM
Have only heard of cranks snapping when heavily modified (300hp, 800-900nm)
The Following 2 Users Say Thank You to nissannewby For This Useful Post:
PMC (2nd February 2014), threedogs (15th January 2014)
15th January 2014, 09:58 AM
Smart like tractor
nissannewby
And using a viper clutch
I have seen a few cranks at gympie diesel that have hairline cracks around the 6th cylinder
96 GQ coil/Cab
08 G6eT
The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
cookman450 (15th January 2014), PMC (2nd February 2014)
15th January 2014, 09:59 AM
some serious misuse ?
maybe an original defect that got through
is it snapped clean or twisted ?
the one thing wrong with middle age ...is knowing you will grow out of it !
15th January 2014, 10:02 AM
Smart like tractor
From what I have heard aswell, big power big tyres, stock gearing and dumping the clutch play a big part in crank damage too
96 GQ coil/Cab
08 G6eT
The Following User Says Thank You to Ben-e-boy For This Useful Post:
15th January 2014, 10:42 AM
The ute is very stock no mods at it was owned by a cocky before me one owner from new and when I owned it it only did some very mild beach driving there was a new clutch fitted just before I bought it that could be the problem or maybe the previous owner being a cocky might have towed some heavy loads??.but as to lack of maintenance it looks smick internally very very clean only a tiny bit of metal in the sump which is to be expected after the crank snapping the oil pick up,squirters,etc look like new
2nd February 2014, 11:21 AM
#8
useualy caused by, abuse (excessive rpm, heavy launching, jumping and landing flat floored) out of balance flywheel or clutch. they are the most common problems
22nd February 2014, 12:47 PM
#9
The bolt for the harmonic balancer can loosen up
22nd February 2014, 03:38 PM
#10
Bet that cocky could tell you some stories,some cockys I know are rough on gear.
