Page 133 of 135 FirstFirst ... 3383123131132133134135 LastLast
Results 1,321 to 1,330 of 1342
Thread: All Things Chev
  1. #1321
    472 Post(s)
    Merry Christmas Ralph Mate!
    Don’t deaden it, embrace it
    You wished for a tractor and scored it
    472 Post(s)
    Been thinking about a Sandy SeaChange Northern retirement in years to come, possibly downsizing to a 6.2L when these Magnificent Mexican Twactor cold mountains start wreaking havoc on my joints
    https://youtu.be/I97Ewg7U31w
  4. The Following User Says Thank You to MB For This Useful Post:
    jay see (26th December 2020)
  5. #1323
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    roof done, this is definitely a young persons game......
  6. The Following User Says Thank You to poindexter For This Useful Post:
    MB (29th December 2020)
  7. #1324
    Apr 2013
    22 Post(s)
    Ok, the drivers has been done, just need to fit carpets.
    Stage one deadener, heat shielding, stage two underlay, now off to the passenger side.
    Did I say this is a young mans gig.....
  8. The Following 4 Users Say Thank You to poindexter For This Useful Post:
    Cremulator (10th January 2021), MB (7th January 2021), PeeBee (7th January 2021), rusty_nail (7th January 2021)
  9. #1325
    Apr 2013
    22 Post(s)
    All right, passenger side done.
    At SWIMBO's request, I will get new carpets. So none installed in the pics.
    That just leaves the doors to do which will be an easy job.
    One thing for sure, if you are near your GVM, the Mass Noise Liner ( the black stuff) will put you over.....
    Put the thermal barrier along the whole passenger side as the exhaust runs under there.
    Glad to get it done before works starts Monday.
    Seats are back in and time to start her up.
    Does work though, you can certainly hear that big boy under the hood, but just a little quieter now, will make touring that much nicer.
  10. The Following 3 Users Say Thank You to poindexter For This Useful Post:
    Cremulator (10th January 2021), MB (11th January 2021), PeeBee (10th January 2021)
  11. #1326
    Apr 2013
    22 Post(s)
    Question guys:
    how long is your throttle return spring?
    I'm having issues trying to get a reasonable feel on the pedal, it is currently way too strong, and I suspect that the geometry is all wrong.
    this is the setup I have,
    If I know what the original length is, it gives me a starting point...
  12. #1327
    194 Post(s)
    Post #57 of my build shows the spring fitted and the same mount bracket - photo is off @MB motor. Brunswick can supply you with the spring and the bracket for sure. I sourced these from them - as usual they sent two variants, a single and a double coil version. Both are dimensionally the same, spring rate just doubles. OD of coil is 15mm, wire dia 1mm 14 active coils on the single. double has 14 active coils also, wire dia 0.75mm, inside of coil ends is 60mm approx overall. I run the double coil version, but carry both as spares.pump spring.JPG
  13. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (10th October 2021), poindexter (9th October 2021)
  14. #1328
    Apr 2013
    22 Post(s)
    Thanks again Pee Bee for the info.
    I'm assuming that you are running that bracket and spring with the supercharger then?
  15. #1329
    194 Post(s)
    Here is a pic showing the bracket and the pump with the spring set-up, taken when the heads were off recently.IMG_6721.JPG
    Accelerator cable to the connection with the gold coloured clip, and bracket configured for accelerator cable and cruise control cable, since deleted. Just noticed my spring in use is the single wire version
  16. The Following User Says Thank You to PeeBee For This Useful Post:
  17. #1330
    194 Post(s)
    If you want the installed dimensions of the spring, let me know and I will put a ruler over it
