Page 128 of 135 FirstFirst ... 2878118126127128129130 ... LastLast
Results 1,271 to 1,280 of 1342
Thread: All Things Chev
  1. #1271
    194 Post(s)
    Quote Originally Posted by thebrod View Post
    Thanks PeeBee
    It's a private sale, and I haven't actually been to see the car in person yet (hopefully next weekend). If it were through BD or a dealer I guess I'd feel a little less nervous as there would be some form of warranty. I wonder if I called BD with the VIN or engine number if they would have the details of what was done at the time of the conversion?
    I think you would find them very approachable, ask for Greg. He is the owner and super salesman, but he wont shut you down.
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    Update as promised, although a day late.
    Technically, nothing has been done, however, the workshop is in the progress of being reorged for the work.
    I'll be convinced when I see progress, or I'll be looking elsewhere...
    that is all.
  4. #1273
    194 Post(s)
    that is all.
    Bloody hell, you must be working thru the list of non performers! I will certainly want to know who isn't to be contacted as I may end up farming mine out as I am struggling with time to do it myself, however really would prefer to do it. PM me if you can
  5. #1274
    Apr 2013
    22 Post(s)
    Update time.
    It has started,
    Engine out, engine bay being prepped, firewall is having shiny heat shield/sound deadened material fitted.
    Hydroboost brake booster is going in.
    Looking forward for trial fitment of engine and gearbox as I want to see the oilpan to diff clearance.
    The 6.5 blocks lack a trans mounting bolt at the 12 o'clock position, I'll be putting one on with a "beaming bracket" that will bolt on and pick up the mounting hole on the trans.
    I'll post pics when I checkout progress this week.
    that is all
  6. The Following User Says Thank You to poindexter For This Useful Post:
    PeeBee (26th May 2019)
  7. #1275
    May 2019
    Hi all, currently puting together a turbo kit for my gu 6.5 and looking for a decent large top mount intercooler. BD ones are too small imo and the cross country set ups are $2500. Any recomendations?
    194 Post(s)
    Jump onto the Aussie P400 Optimiser facebook page - quite a few guys on there that have done the yards you will benefit from.
  9. #1277
    Apr 2013
    22 Post(s)
    Update time:
    Engine is together after the gear drive and fluid damper update.
    Trans is trial fitted to engine and "beaming bracket" design has commenced.
    Existing engine mounts removed from chassis, and new brackets are next to go on.
    I'm keen to see the engine in "the hole" to assess the exhaust and fan to radiator clearances.
  10. The Following 2 Users Say Thank You to poindexter For This Useful Post:
    0-TJ-0 (22nd July 2019), MB (22nd July 2019)
  11. #1278
    Apr 2013
    22 Post(s)
    Alright, time for an update:
    The engine has been trial fitted into the engine bay and positioned as per the Marks adaptors bits.
    I'm not happy with the location, so, the position will be revised approx 35 to 50mm rearwards to allow additional clearance to the radiator.
    From my understanding, this is a common problem.
    There appears to be plenty of room to move at the rear of the engine, with the drivers side cylinder head to dash panel being 70ish mm gap at the moment.
    Interestingly the upper pulley seems rather high.....
    I'll be looking into the oilpan to front diff clearance to see if I can lower the motor.
    that is all.
    see pics
  12. The Following 3 Users Say Thank You to poindexter For This Useful Post:
    MB (3rd August 2019), PeeBee (3rd August 2019), Rossco (3rd August 2019)
  13. #1279
    472 Post(s)
    Beautiful Stuff Ralph mate!
    Huge work both your good self and PeeBee are putting in, Legendary Blokes!
    Please do massively consider as you’re already above onto front diff clearance to P400 sumps mate.
    Higher power, hotter oil, originally were designed about 3.0L too less IMHO nuffy opinion mate!
    Highway Only Weapon Tugs are for Cheators
  14. #1280
    Apr 2013
    22 Post(s)
    Yes I'm very much keeping an eye on the oilpan to diff clearance, no suspension limiting for me! I'll modify the oilpan if needed.
    Engine position 2.0 will happen this week to confirm final location.
    Then the fun begins.... integration
  15. The Following User Says Thank You to poindexter For This Useful Post:
    MB (6th August 2019)
