Hullo all, I have been a member for a while now, my son & I joined together when he bought his patrol. I have now bought a 4x4 as well, unfortunately not a patrol , a short wheel wheel base cruiser FRP top with a Brunswick 6.5L conversion done in 2005/6. I was wondering if anyone has had a similar problem to what I have experienced only a few times, problem is, when going around a corner RH down, not accelerating, just steady throttle it suddenly gives a bit of a boost. This has only happened about 3 or 4 times & could be a bit disastrous if the road is a bit wet. i was thinking maybe there is a loose wire on one of the heater coils, I can't think of anything else that would cause something like this in a diesel, the only other thing is I am just imagining this, or just too much lead in the foot as Kev says . any help will be appreciated.
Thanks guys.
Just a quick bump for ya dad. I think it has something to do with the fact you love the sound of it and you can't help yourself. I know I wouldn't be able to. Lol.
It could have something to do with a loose wire on the injector rail and it not firing on all eight until it connects.
Sent from me using Forum Runner
Live life, Love life.
Snatch straps on towballs can harm and/or kill!!!!!!
yea it is mechanical pump, conversion was done 2005. yea it also has a lift pump.
I would be starting with checks on the electric lift pump and all fuel lines. You may have a restriction, something could also be resting on a fuel line and going around a certain corner might relieve the line allowing the right amount of fuel. Also check the return to the tank is clear of restrictions.
Right, I checked all the lines, all ok, there was 1off return line that was loose so i snipped a bit off & re-fitted it, made no difference. i checked all the glow plugs with multi meter, & there were 2off that had open circuit so i'm looking for replacements, surely the glow plugs are only used on start up & if 2 were not working it would be a bit rough when cold & then improve as the engine warmed up, they wouldn't cause a surge in power if you going at a constant speed, or would i be wrong in assuming that (please say I'm wrong). The lift pump is mechanical & if the diaphragm was blown I wouldn't get any fuel.
Would anyone in WA know where I would be able to get 2 glow plugs for a 6.5L chevy, AC 11 G is the number on them. The local Auto 1 has tried numerous places including Coventry's with no luck.
