Page 104 of 135 FirstFirst ... 45494102103104105106114 ... LastLast
Results 1,031 to 1,040 of 1342
Thread: All Things Chev
  1. #1031
    194 Post(s)
    Ralph, BD supply a cheap in line filter pre the lift pump. I change this every 5000klm with the oil. I also run a 100um pre strainer down near the fuel tank, which is fitted with a 12v heater mat for the colder month trips. I run a CAV filter with clear glass bowl in the engine bay for final filtration and change this every 5000klm at oil change time as well.. I tried to duplicate this filtration at the fuel tank end, however had to 'retreat' to the strainer as the lift pump would not suck and push thru 2 CAV filters. When I remove the bowl to inspect it, first did this at 1000klm, at first oil change, it was clean and now water of scum/sediment, so happy with this set up for now.
    I bought a spare lift pump off BD and they charged me $250. I checked the model and could buy the same pump ex USA for $80 including freight. I can dig out the model for you if interested, but will be tomorrow as its in my spares box under the truck. I think it is rated at something like 150LPHR at 12PSI - apologise for the mix of units.
    What are you guys doing for lift pump and filtration?
    My rig has a standard el cheapo $20 inline 12 Volt pump.
    Connected to a standard el cheapo $5 Ryco inline throw away 'pre' filter.
    Which pumps into a $120 Donaldson 3 Micron Filter/Water Seperator
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    PeeBee (11th February 2018)
  5. #1033
    472 Post(s)
    the service manual says 7.6 liters (8 qts)
    Thanks Ralph, correct you are mate! Just checked the military manual for pre-2000’s and it also says 7.6L including filter. My current extra 1.0L is including the existing crappy cooler and lines I should have written. As before I want more ‘total’ in this old gal :-)
  6. #1034
    472 Post(s)
    I believe mine is all old stock/original TD42 gear mate. Lift pump on chassis rail appears OEM, Filter is (your old mob) Bosch 1 457 434 281 which I believe is OEM Nissan too.
  7. #1035
    472 Post(s)
    Found this helpful little guide from Dayco USA confirming ET’s Amps versus Belt selections. Was recently toying with the idea of a 6 rib/groove short Holden serpy to the beasty alt but perfect alignment is looking trickier than first thought. Back to the drawing board with Dual Vee’s me thinks now!
  8. #1036
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    Anybody had a recent conversion that can tell me wether the Brunswick radiator is now alloy or old style bronze. Been quoted 1500 to replace my radiator which is leaking.
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
  9. #1037
    194 Post(s)
    Their radiators are brass. My conversion was done 15 mnths ago. They did not offer me an alloy one.
  10. The Following User Says Thank You to PeeBee For This Useful Post:
    Ian2011 (27th June 2018)
  11. #1038
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    My radiator is an ADRAD, it's alloy
  12. #1039
    194 Post(s)
    Did BD supply this? I think thats the question, do they supply the copper or the alloy? They certainly manufacture their own copper/bronze/brass radiators, which was all I was offered when I had the conversion done.
    By the way Ralph, how are you progressing with the P400 installation - all done, on the road, happy?
  13. #1040
    Apr 2013
    22 Post(s)
    Yes it was through BD cost was $1545, my builder recommended the ADRAD also.
    Project P400 is not on the road yet, will get update this week. Has been slow mainly due to commitments on both sides.
  14. The Following 3 Users Say Thank You to poindexter For This Useful Post:
    Ian2011 (27th June 2018), MB (28th June 2018), PeeBee (27th June 2018)
