Page 95 of 95 FirstFirst ... 4585939495
Results 941 to 946 of 946
Thread: All Things Chev
  1. #941
    Cheers Phil, was playing around with that earlier and found using the existing bullbar tabs sets the cooler back too far and I can’t open the bonnet. It’s because the Millweld bar is set so far back for entry angle. These tabs aren’t being used so considering cutting them off to bring the cooler almost hard up against the ARB light bar brackets and on a 20 degree angle. Do appreciate any and all ideas before I hack away and butcher it :-(
    64 Post(s)
    Can you reverse the feet and point them inwards, them mount the cooler horizontal instead of vertical? Or mount it horizontal and modify the angle foot - chop a corner off and re-drill on hole to make it fit neat with the back of the lightbar - which won't be there after you send it over to me!!!DSC01975.JPG
    Manufacturer of the Complete Camp Oven System
    Website:http://davesstuff.net/
    Vendor Page: http://www.nissanpatrol.com.au/forum...ar-That-Works/
    Tuturial Video's: http://www.nissanpatrol.com.au/forum...ted-on-Youtube
    MB (14th January 2018)
  5. #943
    Just flipped the coolers brackets, (please do check yours Phill mine were only finger tight outa the box) Noticed there is a drain bung on them which is cool ! It really does seem to be screaming out for U bolt thingys or light bar clamps as the brackets are now back inside the welded line of the straight part of the bar.
  6. #944
    64 Post(s)
    You might have to insert the bolts first into the feet and mount the bracket os put the nut on top - looks heaps of room
    Will it fit between bullbar and bonnet in any fashion when horizontal is perhaps the question and if so what are the advantages of vertical, horizontal or angled and can you make it work? -- Of course you CAN.
  7. The Following User Says Thank You to PeeBee For This Useful Post:
  8. #945
    Just worried if I run it horizontally under the bar it will be blocking some airflow to the grill which I’ve always kept as clear as possible nowadays. Judging by the drain/bung on these they look meant to be mounted vertically so the bung is at lowest point.
  9. #946
    64 Post(s)
    You don't need the bung, what are you draining? Sit it up on top of a plate mounted off the bottom of the existing BB tab.DSC01976.JPG
